Fuel trim at MAX
BG1988
having an issue with the fuel trim (positive )it's maxing out and tripping a CEL i.e Long term fuel trim said between 16 and 34
New Throttle body, new MAF, New MAP, new Baro.
also the O2 sensors are a bit funky readings as well..
I can watch sensor 2 slowly rise on sensor #2
mpg dropped to 12.5mpg
idle is ok and stable. ( sometimes misfires, a single misfire) on a cold start esp if it gets into the 30s at night)
no "excessive revving "
no misfire while driving i.e 1,000 1,500 2,000 3,000 rpm range(i don't take it above this. 3k is my max rpm i go to ..)
Enters closed loop (CL)
Cat temp reached 565C so it's dumping fuel typically it's around 360-370C or so under normal conditions
the only code was P0430 AND a pending P0430 code, which is the enabled condition and is part of the "Diagnostic enable condition section"
i.e Predicted catalyst temp was 550C and above for 3600 seconds non-contunuosly..... ready to take it to the junk yard and get a toyota 4runner at lest that shit is reliable :D
I'll try and put the original MAF sensor (a known good one)
edit the other seemed to help but the long term fuel trim was hanging around 10.9
I think there might be an issue with the Fuel pump FRP is 297-312 KPa or 43.51PSI ish
I noted that it instantly goes to 400-410KPa 58.3-59.4 PSI when in "auto stop mode"...
exp500
What does your scanner report live ? You probably need the VCX Nano and laptop with Factory Service Manual to figure this out.
B
BG1988
i ran fuel injector cleaner showing 3-5 at idle now(in gear on both banks warmed up) before i was idling at 10.9 in gear.. not misfiring at start up anymore....(single misfire upon startup..)
exp500
Have you put a fuel pressure guage on it to verify? Without the manual handy guess is its low. Or computer and/or relay dropping out. Pretty good troubleshooting chain in the factory man.
B
BG1988
everyone told me it was normal. 300KPA = 43 psi
exp500
low side of making it. And thats the standalone guage correct? Meaning you verified your electronic toy is accurate? And are you in Canadia? whassup with your numbers?
B
BG1988
Vacuum leak.
it has all ready been checked for a vacuum leak.. and it's not misfiring on startup...
the computer is calibrating the fuel trims
it runs a lot of better now then it did before I just need to get a AFM disabling device and auto stop disabling device, so I can have my EVT gears with v8 100% engine...
you want to know I know it's fixed the calculated Temp of the Catalytic converter is lower 420-450C instead of the 530-560C that must mean it's not dumping fuel into the converter"
this is at 2,000 RPM 50mph M4
430C is the normal working temperature for a Catalytic converter
I remember now, has the Fuel Trims been reset along with the Alcohol Content with a tankful of E10?
belveman
