Need help!!!
MalcDogg
Hey guys need some help I’m new to this forum
I have a 2008 Chevy Tahoe 5.3 LT
Got a misfire Cylinder 1 change plugs wires coils and injector still getting code
I noticed it’s not switching from v8 to v4 also traction control and stability message on dash board also MIL indicator code
Can anyone help??????????
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
Members here will chime in with AFM info that could be related to your problem. I would still want to do a compression test on at least #1 and #3 cylinders, if not all 8 cylinders.
MalcDogg
MalcDogg
did a compression test as well looks like the valve isn’t moving but not to sure I’m getting spark because it shocked me
since when does a 2008 have afm?
I thought the AFM was available starting in 2007?
"Back in 2007, GMC introduced a feature for its motors, called the active fuel management system, or AFM. The company implemented it to increase fuel economy, get better horsepower, and more torque."
wsteele
I think this is a duplicate thread. It is going to get very confusing very fast unless a mod deletes one.
On the problem at hand, are you getting a #1 misfire code (P0301) on a scan tool?
When you say the valve isn't moving, what do you mean? Did you pull the valve cover and see one of the #1 rockers not going up and down?
1BADI5
DMV
Well the AFM is on cylinders 1, 7 and 4, 6 - so we're on the right track.
Could be a stuck AFM lifter or the solenoid for cyl #1 on the VLOM is dead.
- Both would account for a PO301.
- Low or lack of oil pressure registering to the cyl #1 solenoid
- An inactive solenoid would also contribute to the AFM not activating as a failsafe.
You're going to need diagnostic tool that can really get into the PCM and test functionality of the AFM
I have seen conflicting info on this, like that some engines had afm but it wasn't turned on, that it didn't start until 09, the hybrids had it first or something etc, etc
wsteele
To my knowledge, all the 5.3L had AFM starting the 2007 model year. Mine is a 5.3L 2007 ands has it.
I don't even know, never verified what does and does not but I keep seeing post's saying it started 2009, then I find this post :shrug:
"They introduced it in 2007 with the gmt900 trucks. The 5.3 and 6.0 had afm. The 4.3, 4.8, and 6.2 did not".
wsteele
I think the 5.3L all had AFM (mine LMG, definitely did). The Denali's (6.2) came later. I think the only 6.0 that got it was the Hybrid. But all of that is from what I have read here, so, YMMV... :)
MalcDogg
MalcDogg
So I ended up putting some fuel cleaner and catalyst cleaner in it so far everything is working fine now
But I still have the issue with the my engine light and fog light and cruise control not illuminating on the dash
Scan tool says MIL indicator code
Any help with that
wsteele
Any help with that
MIL relates to the fact that the yellow/orange engine light on the dash is/was illuminated, normally referred to as your Check Engine Light. Does your scan tool display any other codes other than “MIL”.
It can occur that something like a misfire will set a code and the CEL and even when you fix the condition that set the code, like you fixed the number 1 misfire, the CEL and the code that set it, won’t reset, even when cleared by your scan tool, until the Monitors in the PCM have some driving conditions met with no further codes being thrown. That is, you may have to drive it so the PCM resets the permanent code.
Just a wild guess. I have no idea what effect the fuel cleaner and catalyst cleaner might have on a hard #1 misfire.
GMT900 SUVs equipped with the 5.3 all had AFM from the beginning. As for 6.0 motors used in the GMT900 SUVs, the Hybrid motors had it as did the L76 too. The 6.0s in the 2500s did not.
MalcDogg
MalcDogg
so the MIL code I’m having I was having before the the misfire
I was installing my headliner and the battery died when I jumped started that’s when I notice when I turn the key on the engine light didn’t come on and some other lights as well I changed the odometer thinking that the bulbs was burned out even with the new cluster still nothing I also noticed that the rearview mirror it’s working either
I looked a few options one said change the alternator but that’s working fine I’m lost
wsteele
That makes two of us.
TejasPitt
