mcgaughys 2/3 drop
05ukon
Cali
after intalling the spinddles found out that the stock 17 inch rims wont fit any more.?? on the spinddle specified 17" or larger wheels. I cut the sensor rods and now compressors do not turn on. normally they would turn on after starting truck. one side in the back is higher than the other could it be the sensor rods ??
warrlac
Minneapolis, MN
Autoride sensor links...
Do you have the 2/3 drop kit addendum for AUTORIDE? They give you another pair of sensor links. If memory serves me correctly, you take the new sensor links and put them on the rear pair. Take the factory link rods that were on the rear and replace the factory front links with these...
I can PDF the instructions and send them if you don't have them... :)
I have 18 inch Escalade Wheels but don't have the spindles installed yet (only drop keys). Will advise once the spindles are in...
05ukon
Cali
Yeah I even cut the screw in the spinddle and the 17" didn't work. With 18 you will be ok. I don't have the new sensor links that was my problem I have to find were to get new links. I cut the old ones but might of cut too much or too little don't know yet I'll figure it out some day:emotions122:
briannorris
