2.5/1.5 leveling kit help
J
Jnull
PA
I’m sure it’ll be fine, they say with their leveling kit you MAY need to run a 1/2” spacer with factory 22s which have probably double or more offset then my wheels so I’m not concerned about it.
nick14226
Look forward to seeing the finished product!
dmurph112
On my 17’ suburban, I did a 4” readylift SST and a set of 20x9” +01 offset with Continental TerrainContact a/t 285/60/r20 tires and there was quite of bit of rubbing. I was expecting maybe a little but it was making a lot of wheel liner contact. I thought I would have been ok after reading the wheel and tire spec for the readylift. I cut out the metal behind the liner did a little bending and put a self tapper screw in to pull the liner back. Watch for the A/C lines on the passenger side.
J
Jnull
PA
On my 17’ suburban, I did a 4” readylift SST and a set of 20x9” +01 offset with Continental TerrainContact a/t and there was quite of bit of rubbing. I was expecting maybe a little but it was making a lot of wheel liner contact. I thought I would have been ok after reading the wheel and tire spec for the readylift. I cut out the metal behind the liner did a little bending and put a self tapper screw in to pull the liner back. Watch for the A/C lines on the passenger side.View attachment 269930 View attachment 269931 View attachment 269932 View attachment 269933 View attachment 269934
Thats crazy cause I see a lot of guys with only 2.5” up front clearing the same tire. More positive offset would probably help with clearance. Looks great by the way.
Hodmjstone
