Best suburban grill for light bar
Jnull
PA
With the size of our family increasing we traded my wife’s 18 Sierra 1500 x terrain in on a 16 suburban LT. She has a list of demands to make it cooler and one of them is a light bar behind the grill along with headlight upgrades because the factory ones are terrible.
Are there any grills other then the lower trim honey comb ones that will maximize light bar output from behind it? This is the new ride and the current grill won’t allow much light out from behind it. I’m not against factoryish looking aftermarket units either, I plan to color match it either way.
gat0r
DFW
looks like you have an LTZ grille now
you would be surprised how much light a light bar puts out. id think you'd be ok w/ that one.
Z71 or LS/LT(mesh) may work out better
the Z71 grille has 1 bar on top & 2 on bottom (vs the LTZ - 2 bar on top & 3 on bottom)
(think LT had a 1 bar on top & 2 on bottom... as well as mesh option)
RST would prolly block the most
aftermarket wire mesh would block the least
J
Jnull
PA
I definitely wouldn’t be surprised how much light a bar puts out. I’m pretty into lighting since my drive to work is a minimum 1.25 hours through desolate deer and elk infested back highways with no cell service for miles. I have a 40” baja designs hi power on the bumper at 44,600 lumens and baja designs XL80s on the pillars with S1s pointing off the sides of them. One XL80 is brighter then any 50” Amazon China light bar. It doesn’t matter how much light any given bar puts out if it’s almost completely blocked. My truck.
I do like the black mesh inserts a and looked into them but most of what I’m finding for that kind of stuff goes overtop of whatever’s on the factory grill. I found some complete replacement aftermarket grills that look good but the mesh and grill shell are all one piece and that would be difficult to paint and look “clean” without just painting the entire thing mesh and all one color. Where would be the best place to find a Z71 grill at?
gat0r
DFW
thats a helluva a bumper. i remember when those came out. i wanted one so bad, but couldnt justify the price.
there are replacement grilles that have chrome outer ring & the mesh is 1 piece & all black. it would look good on the above burb
there are also 1 piece grilles that have light bars built in ;)
J
Jnull
PA
It’s a salty bumper but cheaper then deductibles every other week from hitting a deer lol. I got mine half price used, even shipped from texas to PA.
I’ve seen the light bar grills but they’re not my style, I prefer a factoryish look. Also most grills I see like you said are chrome and I’d like a paintable one. That’s another one of my wife’s demands get rid of all the chrome.
gat0r
DFW
yeah, some of the built in ones are odd, but at least its an option. ;)
cant blame her. im in process of dechroming mine.
have you peaked @ carid? they are a vendor here.
there were 2 i saw. T rex & SpecD
1 was metal/powder coated & other was ABS plastic. should be able to paint both of them
the ABS one is significantly cheaper price wise
J
Jnull
PA
I did but I’ll have to look again and see if I can find the ones you’re talking about. I didn’t know they were a vendor, brand new here. Appreciate the help man.
Yea I’m not into chrome either, I dechromed my truck as well. I did find pre cut black vinyl kits for the window trim on the suburban, I’ll have to figure something out for the headlight trim.
gat0r
DFW
vinyl wrapping the grille surround & headlight brows is what i am getting done.
J
Jnull
PA
what colors your rig and what color wrap if you don’t mind me asking? Ours is white diamond tri coat and I’m not sure if black wrap on the headlight trim will look right on a lighter colored vehicle.
gat0r
DFW
black burb
i wanted black chrome vinyl but 3m stopped it due to QC related issues.
so decided to do black brushed aluminum for something different
J
Jnull
PA
black burb
Sounds cool, black paint definitely makes it easier then throwing random black around with white paint.
Are there any factory paintable grills? All the ones I’m seeing are chrome and I’d rather not paint over one of those.
gat0r
DFW
just the RST ones, they come color matched to a couple of colors
you could always try to sand/soda blast & spray a few coats of adhesion promoter before paint
J
Jnull
PA
Paintable ones are hard to find, there’s one on eBay that’s scuffed up but it’s $350 and I’d probably have to change out the inserts since it’s the 1 top and 2 bottom horizontal slats.
chrome can definitely be painted over but I’d rather not risk it on a tri coat paint that will cost a lot to have done.
gat0r
DFW
the Spec-D one on carid was under $200
might be worth playing with... all 1 piece too
the other was over 1k
J
Jnull
PA
There’s this one on eBay that’s factory looking, my only concern is the mesh being integrated so I’d think it’d be difficult to mask off where the mesh meets the shell
Hodmjstone
