Stainless steel brake lines (front only)
treehan77
TYF Fiend
Crestview, FL
Can anyone give me a link to correct FRONT only stainless steel brake lines? I’d like a set that uses the OEM mounting points etc of possible. Thought I saw good ridge does this, but can’t find it in here.
So these mount them same way as OEM? Or zip ties? Have you used these yourself?
I had someone install mine and he used a zip tie to hold it down. It functions for my needs, so I'm not ocd about it. Honestly not sure if it uses oem mounting points or not, but I'm sure it could be done if needed.
corvette744
2004 Z-71
Northern illinois
I did the kit from goodridge.Only problem i had was with the rear crossover line.I had to put a new fitting on the stock line it wouldnt tighten up-you have to remove your spare tire also so make sure that works.
Goodridge brake lines 023.JPG Goodridge brake lines 027.JPG Goodridge brake lines 026.JPG
Conedaddy
