03catburban
Georgia
Same with mine, they're tight, but there's no peg or lock for the socket itself, so the socket can twist all the way around--but they don't pop out.View attachment 264269 View attachment 264273
Does yours not have the little peg to keep it from twisting all the way around?
PG01
Up here to the right
Getting ready for winter and got blessed with decent weather for Thanksgiving weekend, so here goes...
Water pump has been whining for a bit, which of course prompted a domino effect. I've had parts in the garage for a while now:
AC Delco OE water pump w/ stat and housing
Idler and tensioner pulleys
Serp belt
A/C tensioner & belt
Then some extras to make the whole project worth it... lol
Heater tee fittings (NOT PLASTIC!)
Dexcool, distilled water
Constant tension (OE style) hose clamps and some silicone hose pieces purchased through McMaster Carr.
Since I was replacing the tees at the firewall, I got the Dorman piece with the metal tee by the pump. Then I found this and couldn't resist....
https://www.ebay.com/itm/282998165401
Friday night I drained the system via the lower radiator hose. Then I filled it with the garden hose, ran it for 10-15 minutes, and drained again. I repeated this 5-6 times while I sipped a few brews until it was running clear. Then I pulled the pump and let everything drip overnight.
Saturday, I did the job. Everything went smoothly and according to plan. I pretty much just copied @iamdub on the tees (cutting the rear lines to fit). I used the peices of silicone hose and spring clamps from McMaster. Yes, I put the wiring back where it belongs when I was done...
Then I replaced the A/C belt and tensioner. I used the green Gates belt. Installed the AC Delco OE pump, tensioner, idler, and serpentine. Refilled with new Dex and distilled H2O.
Love the red silicone hoses from Glenn's. The truck is definitely faster now and has exactly ZERO plastic tee fittings in the cooling system! Topped it off with the awesome NBS sticker they sent!
Nice work Nate. Always 1 upping me. ;)
Dantheman1540
Sugar Loaf Mountain
IDK about yall but I hate side post battery terminals more than I hate the chaffing you get from walking too much in wet undies. Stumbled upon this product on another forum and thought some people may like to see it. I think This is in my near future along with a big 3 upgrade.
https://jims-machineworkx.myshopify...t-down-style-set-screw-type-battery-terminals
That's nice. I HATE the side post setup, but these will only work if you have the dual post battery setup? Top and side?
RobsFreeland
Old wild land firefighter
Whidbey island
Spent most of the day removing exhaust sensors on 04 Tahoe. Couldn’t free the nuts on the down tube.... had to cut both sides. Will replace with black heart headers. Removed spark plugs and then the harmonic balancer. Will remove timing cover tomorrow for tdc so I can pop the heads off. New lifters, springs, cam etc. I’m tired of squirming on my belly like a reptile.
Dantheman1540
Sugar Loaf Mountain
K6536 vs K6536HD
About to do a front end rebuild since I have a wheel bearing going out. Mostly need an idler and pitman arm and found Moog K6723 for a good price. I see 2 different Moog Pitman arms and not sure which one would be better obviously the HD sounds better but is there any real difference or a totally different part I should look for. Not looking to spend Kryptonite money since the truck isn't 4wd or on big tires.
Thanks guys!
P.S. I did try searching but the search bar is still useless.
048tahoe
