It just died
druiddonn
My 04 Denali died all of a sudden while in traffic when I finally did get it started it makes a slow grinding sound the tow truck driver thinks it's camshaft bearing but I'm not sure what else could it be
No codes? When mine were going it sounded like a lifter tick. Does the sound speed up when you rev it? While in park or only when it's moving?
druiddonn
druiddonn
Only when it's in park the sound does change if I rev it and I haven't driven it cuz the sound sounds really bad it's a very slow grinding sound possibly from the bottom of the engine I did remove the belt to make sure it wasn't the alternator or the water pump and the noise continued
avalonandl
Troy, MICH & Naples, FL
Uhhh- drain oil and look for metal shavings. A spun bearing makes all sorts of noises. Also the crank may have shifted forwar/back and rubbing....NG
Ossipeelake
