05Single
afraid of the dark
What happened was those 9 were running from NYPD and ended up in Florida then when NYPD Detecives found them in FL they fled to Alaska...
Sounds about right lol.
I talk to a lot of people who move up here , usually by themselves and don’t know anyone . I ask them what made them come up , they all say “I’ve always wanted to live in Alaska” .
Lol people always want to visit Alaska , nobody wants to actually live here so what or who are you running from? Lol
Right???
iddqd
San Francisco, Comifornia, USSA
Was a nice day (< 40 F ), so I went to the junkyard. Thought I'd see just how difficult it is to remove the upper section of the steering column. That Youtube video I posted earlier made it look like a pita. Actually doing it wasn't so bad. The hardest part was removing those damned snaprings. I pulled 3, and 3 clocksprings, for practice.
View attachment 260138View attachment 260137
To hell with trying to fit that larger insert into the new steering wheel. Oh well, they can't all be good ideas.
I've got a small play in this joint. The pastic insert is probably worn out. How about the ones you pulled out? Are plastic inserts in them in decent shape? I was thinking about going to junkyaard and puuling one from a low milage wreck
Dekindre17
I installed efans on my 2004 tahoe. I found an oem harness from a 2005 tahoe and bought a set of 7 and 7 blade efans from ebay for $80.
66DBE2F0-7E46-4765-A050-47BF214866BD.jpeg A50D03DB-4EB8-440B-961E-0D8F630E9D9B.jpeg 8C028AC5-7226-481C-B19F-A78921835226.png EFFFF4E9-77C0-4F70-AC18-F3FE4BEF8BD6.jpeg
Denaliz
Frisco,TX
I did the wiring myself there’s nothing 10k about doing a big 3 upgrade and adding a better performing battery. Most of the fabrication I had the pros do. I’m always happy to knock out grunt work and let the experts do what they do.
I’m more than happy to provide parts/product info to anyone who needs it.
I recommend to not fall pray to inferior 1/0 wire that will rust. There’s lots of ****** stuff out there and equally lots of good quality 100% ofc that will not break the bank.
nice, but none of the shops around here are balling like that and I would guess most people are not looking to drop another 10k on audio and wiring. I just wanted a little extra juice to feed my subs and a extra battery so I am less likely to be left walking home. certainly is nice when you have access to places that do custom work like that and have the extra money :waytogo:
Sam Harris
PCM tuned, I found the factory parameters on a forum from two different sources and had my tuner adjust them accordingly.
On this note.. I have everything other than the fans for my efan swap.. I’ll be doing it soon, but obviously need to have BBP turn the efans on in my tune. Any reason to wait? I can’t imagine there’s a problem with enabling them ahead of time, but maybe so.
No, in fact BB told me they turn the pins on as standard protocol on every tune so contact them to see if they’re already enabled in your tune. @BlackBearPerf hey Shannon can you chime in here or maybe check to see if Sam is GTG?
Sam Harris
Nice! That’s even better! Anyone have a part number for factory efans in a 2004+ Tahoe /Yukon?
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
Correct we do enable electronic fan control by default in the tune on certain vehicle years. Sam's should be enabled I will check and see.
ASG-MikeS
