Considering 2010 GMC Yukon SLT
SiWilli
Hello, Looking at a 2010 GMC Yukon SLT that has 102,000 miles. Any thing in specific I should be looking for or concerned about with this one? It has good dealership maintenance records. Will be a daily driver, I have 3 teens plus their friends and all their crap. No major towing needs, just our jet skis a few times a year. Anyone have any ability to look up VIN? Thanks! VIN#: 1GKUKCE08AR268818
S
SiWilli
Thanks, I had looked there. Was mostly Tahoe and Suburban so figured I would ask. Not sure if it reflects a lack of issues, or owners here :)
they are the same truck just wrapped in a different cloth
at 100k there are regular maintenance items to be done
02 sensors (all 4)
plugs/wires
both belts
ALL fluids flushed, brake, steering, trans, diff's, coolant
inspect suspension parts, it's typical for the shocks/struts to be worn out at this mileage, typical failure is around 84k miles
2010gmcyukon
Midwest
02 sensors (all 4)
plugs/wires
both belts
Agreed, I bought mine at 98k and did all these things except shock/struts. I'm at 110k and about to do them. They are all fairly simple to do yourself to save a few hundred bucks.
Welcome to the Forum from NH.
You are already receiving replies to your question. I bought my new-to-me 2007 Yukon XL Denali at 125k miles, and I have absolutely no regrets over this purchase.
tsuintx
DFW
As long as you are aware of the the potential issues with AFM and are fine with it, I think the rest is just the stuff you should check on any other used vehicle: sights, smells and sounds.
The truck looks like and all, but 16 grand??? Wow! But if that's the going rate in your area, then there's not much you can do about it. I'd still try to talk them down, though.
S
SiWilli
Thanks, and yes that is the lower end on pricing here!! I plan to negotiate and/or try for some freebies
That's an SLT1 option package and is a 4x4 but you'll have to determine whether or not if it has 3.08 (GU4) highway gears with a single speed transfer case (NP0) or 3.42 GU6) gear with the 2-speed transfer case (NQH). One is more suited for towing and going off-road than the other. The RPO sheet is located in the glove box. It will probably have the basic ZW7 Premium Smooth Ride suspension, no air compressor or shocks and a nice bonus would be if it has JL1, the Integrated Trailer Brake Controller (located beneath the light and 4x4 switch).
Test everything out, every switch, each button, make sure they all work. The back up camera comes on in reverse on the left side of the rearview mirror if it has a radio and not a navigation unit. It should not have a navigation unit as I believe those were for SLT2 trim levels and higher. It should have remote start but no power tailgate. Test the rear glass window liftgate, both with the fob and by pressing the secret button just above and to the right of the license plate. The rubber rots and the guts of the switch falls out.
If it has a 2-speed transfer case, put it into 4LO and Neutral and back again, but remember, 4x4s protest when driven on hard surfaces. Download the owner's manual and read up on how to switch into those modes, don't assume the salesman will know how to correctly do it.
I own and prefer the Yukon XL and like the creature comforts of the SLT2, the heated seats and memory seats, etc. Also prefer the captain's chairs in the second row compared with the bench but to each his own.
Keep the fluids clean and these will last a long time if not abused. I doubt the transmission fluid has been changed, do it right away and thereafter even sooner than the severe service schedule.
You don't need the better towing ability for just a couple of jetskis, but having 4LO is nice on a slippery boat ramp. Make sure the parking brake holds well! They are designed to hold the vehicle and trailer at maximum GCWR on a steep incline; if it is in good order.
tsuintx
DFW
That's a bargain across the country right now. For reasons unknown to me, the prices on these things has jumped $5K over the last several months so finding one at the "old" prices is great.
Damn..., and here I thought I did good getting 11K for my wife’s 2010 Tahoe. :( Guess I should’ve held firm on my asking price of 12K. :D
foxie
London UK
New here, from the UK. I imported a new Tahoe in 2004 and (a long drawn out story over 2 years) it was deemed unrepairable in 2008 ! I've owned many US cars, trans-ams, H2, c6 z06 and more, but am about to look at a 2010 Denali XL 38,000 miles ..... price equivalent to around $23k it's actually a good price for here !! A 2021 platinum escalade for example commands $200k
Joined up here for some advice on things to look out for specific to this vehicle/model. I've checked the basics on the Vin 1GKUKMEF3AR164425 but wondered if anyone could add anything ...
Thanks in advance ..
probably should have started a new thread but this one already has some good info
J
Deennoek
