2002 Tahoe LT-SOLD
GMT800 2005 Tahoe Z71
Navy Supporting Member
Selling my 2002 Chevy Tahoe LT. This rig is in great shape and runs like a top. Work done within the last 2 years: new tires and custom wheels, new rear brake pads and park brake shoes and new rotors, replaced both rear axle seals, front brakes inspected at that time and had plenty of pad left, all fluids serviced in the 2 differentials, transfer case, transmission including filter, brake fluid, p/s fluid. Oil changed with full synthetic 10w-30 oil and AC Delco filter. Has a slight rumble from the 1 year old Flowmaster 50 series muffler. Has the Corvette servo installed to firm up the transmission shifts. Complete tune components a year ago with AC Delco plugs, plug wires, air filter and fuel filter. 1.5 years ago new water pump, AC Delco brand, thermostat, new serpentine belts and all new belt tensioners and idlers, flushed coolant and installed all new 100k coolant. The dreaded drivers seat leather tear has all been fixed. The leather was replaced and the seat bucket pan was welded and reinforced. Has the very rare rear barn door access and has the rear roll screen to cover items placed back there. It works flawlessly. Both sets of front door hinge pins have been replaced. I am the second owner and selling this rig because I just bought a 2005 Tahoe Z71. Tags good till June 2022. Some pics are from before the new custom wheels.
The only thing that could use some attention is the driver's door has some paint scratches and the driver's side front and rear door both show where the clear coat is coming off. Rest of body is straight. Has no rust anywhere. I have spray and pencil type touch up paint for this rig.
All dash controls work and the a/c is cold, front and rear. Heater is hot, front and rear.
Differential gearing is a 3.73 gear (GT4) and rear diff (G80) has the posi-trak limited slip set up from the factory.
Has low mileage for the year at close to 164,000 miles. Comes with extra left and right front cornering light housings, the innermost lens on each is starting to look foggy so I bought replacements and a new right front fog light assembly. The left front fog light was replaced 1.5 years ago and the right looks old so I had bought another one but have not installed yet.
My price is $6000 Or Best Offer. Can call or text or email. If no answer, please leave a message.
For any member here the price is $5500.
Since the pics were shot I have completely wiped down the inside and cleaned the mats and vacuumed the carpeting.
It does not have a third row seat and I asked about that here at the forum and I was told that the carpet in back does not have the cut outs for a third row but the floor under the carpet has the attaching points for a third row seat and the carpet has to be cut for that access. I have never looked. Plus, If you need a third row seat, I just bought my 2005 Z71 with a third row seat and if it does mount up simply because maybe all third row seats for 2000 to 2006 attach the same way, I would sell you my third row seat for $100. Color would be different though.
May be someone here can chime in with all that info.
PG01
Up here to the right
not to clog up your fs thread but...
00-06 brackets and seats are the same. Only need to buy brackets bolts and seats holes are already in the floor on all models.
fyi 07-14 is the same as far as needing brackets, bolts and seats. All models have threaded holes in floor.
gonna go out on limb and say 15-20’s have threaded holes also, don’t need brackets because those third row Seats bolt direct to floor.... GM is very predictable...
I put a third row in my 01 barn door years ago.
and some pics for future reference:
Thank you. I knew someone had said something like that and you even provided the pics.
I just lowered the price again. $6000 to any buyer and $5500 for any member.
Sold it last week for the $6000. Then I turned right around and ordered in a bunch of AC Delco parts from RA for my 2005 Z71.
BadDaddy2003
