Door speaker size
Token11
Alabama
Found this in another topic.
Front and rear doors are 6.5"
A pillar tweeterse are about 1"
Rear pillar speakers are 3"
Rear sub is 8"
Front console sub is 6.5"
Is this the same for a 2005 GMC Yukon SLE?
rgosart
Yes but all you really need to worry about are front and rear doors and the back pillar speaker/tweeters. I am guessing that with an SLE trim you do not have Bose which means you won't have A pillar tweeters or a console sub.
The rear 8" sub was only in the early 2000-2002 trucks. It moved to the console in 03 with the interior update.
Token11
Alabama
Thank you
Supertrucker
Lawrenceville, Ga
front is 6.5"
rear is 5.25"
the front opening is 6.75" but it will still accept a 6.5" and mount fine
if I may recommend you getting RF Punch speakers they are relatively inexpensive and sound amazing on power and will get loud as well :)
Definitely recommend the RF Punch as I Used the RF Punch and I went thru Crutchfield.com and got everything needed for the install no factory wires cut at all and it sounds amazing!!
JonnyTahoe
Minneapolis
I removed those Pillar Tweeters and will not replace them. Replacing all the door speakers with new Alpine 6.5's and Alpine head unit will replace stock radio.
Front and rear door speakers are 6.5’s, front need adapter plates but rears don’t. Be sure to match the impedance of speakers if you’re running on the factory amp especially if it’s a Bose system, since they run 2 ohm and if you put 4 ohms in there you won’t get much output.
JonnyTahoe
Minneapolis
What did you do to cover the holes where the tweeters were?
Just put the plastic back on with no tweeters inside. Nobody would ever know you really can't even tell. Just left the wires but tucked them into that insulation.
S33k3r
Dallas, Texas
Well duh! Now I feel stupid. Sorry for the dumb question and, no, you were nice. It just sucks asking dumb questions.
The only thing I hate more than wasting my time is wasting someone else's.
cpellegrino
