WifesYukon17
What made you opt for the 4600's vs 5100's? I'm wanting to upgrade mine as well. Wondering if there is much difference in ride quality between the two models.
Sent from my SM-N975U using Tapatalk
Mainly because the price difference wasn't worth it for me because they are basically the same shock with the exception of a few minor things. If I planned on leveling the front I would have opted for the 5100s but since I'm staying stock height the 4600s will do just fine. I don't think there is any noticeable difference in ride quality between the two models either. I do know the stock shocks are garbage in comparison with the Bilsteins. I should have the fronts here soon then gotta get those installed. Then I'm gonna go hit some speed humps, that will tell me everything I need to know.
BlackYukon
I'm kind of a Retard
How do the Bilstein 5100's Compare to Fox shocks? I originally was going to raise the rear and get the Fox's but I'v been hearing allot of good things about the 5100's. They're allot cheaper so that's a big plus.
ImMikeLowry
Houston
Installed my RST grill. Took me about 1hr 45 mins. Next up is the color match wrap for the headlights/chrome delete on the window trim/emblems. Currently trying to decide if I want to do a full catback system upgrade or just do the muffler/muffler tip.
Before
After
the 5100's are just regular shocks, the fox are offroad/adjustable, etc
WifesYukon17
On my previous F150 I had 5100s all the way around, on my current I have Fox 2.0s in the rear and will most likely get the Fox 2.0 coilovers for the front. The Fox 2.0s are superior in build quality and use better shock oil. I also believe they dampen and ride smoother while still stiffening things up. If you have the $ I'd say they're worth it but if you're just looking for a little better ride and a little lift in the front and rear with no real plans to offroad then the 5100s will most likely give you the best bang for buck.
nglauer
Has anyone used the Bilstein B8 5160 with the external reservoir on the rear?
I couldn't find details, but are the 5100 series aluminum or steel? I assume they don't use boots?
WifesYukon17
nglauer
Opened these... Now I'm searching for an aftermarket skid for the transfer case or possibly a CAD file for a homemade one.
Subanbur
Tried to install the suspension Maxx Front leveling kit. Couldn’t get to lower the lower arm enough to slide in the spacers. I’m bummed out ☹️
nglauer
Tried to install the suspension Maxx Front leveling kit. Couldn’t get to lower the lower arm enough to slide in the spacers. I’m bummed out [emoji3525]
Call Suspension Maxx, they are awesome. I have bought numerous things from them over the years. Larry is awesome and will take the time to walk you through any issues. Best customer service ever!
Take pictures too, they love photos!
JML07denali
Getting ready to pull a travel trailer we are picking up this weekend with the wife's Yukon. Added proportional brake controller, ditched the P-rated Continentals that came with it, and added air lift bags inside the coils to firm up the suspension. I went with Load range E Ridge Grapplers in the stock size and was impressed with how it changed the look. We are going from a newer F-250 diesel with a 10k trailer to a smaller 5700 lb trailer with the Yukon. I am interested to see how the towing experience varies, lol. We only pull max 3 or 4 hours down around the Houston area no mountains or big hills, just some highway overpasses and have a nice equalizer WDH. I am hoping the 5.3 with the 3.08 rear end can get it done. :driver:
How do you like those tires? I’m looking to upgrade soon. Would love to hear your feedback.
johnsonwillie199
