Rubbing
BossMan74
Just put 26" on my 07 tahoe and it rubbing when i turn? anything mods i can do to fix this and pic can help thanks!!!
onebadrado
Waycross, GA
what size tire you running.. i have 26 on my 09 but the only time it rubs is when i make u turns, im running a 295-30 size tire..
onebadrado
Waycross, GA
i dont know if that tire should make much of a difference, are you lowered, mines at stock height.. some have heated the inner plastic to avoid rubbing..you can try that too..
bigblue
Beaumont TX
i have 305/30/26 on mine and they rub minimal, it basically just the plastic liner, so its not enough to even worry me, just roll em
onebadrado
Waycross, GA
so if i turn lift and right and i feel it rubbing do nothing?
like i said mine rubbed in the starting now it dont cause it has rubbed the plastic enough to where it dont touch it anymore.. i now when i make u turns it rubs. but its your vehicle if you dont like the way it rides take them off and go smaller.. i dont mind mine.. i do 500 miles every weekend from my college to my house and havent had any problems..
TEXAS DEMON
with a vengeance
texas
dont worry after a while driving the tires will burn the plastic and most of the rubbing will go away. i had 6s on a 2- 5 drop.
NASTY GM
Nor Cal
It sucks, but like everyone else said it's only plastic. I did some trimming with a utilty knife. Your 305 is a little taller than the 295, but it gives you a little more protection. I too went with 305's for that reason. This pic isn't the best.
Conor
"Bob's your Uncle"
Seattle, WA
+1. Once the tires wear down a bit you will not notice it anymore. A little rubbing is a small price to pay for rollin hard.lol
CKendrick
