thompsoj22
- Joined
- Jul 21, 2018
- Posts
- 689
- Reaction score
- 718
The KNP should be the heavy duty one, but it is a lot smaller than any of the Tru-Cool ones.
At least, the KNP for 2002 is this one here:
https://www.amazon.com/ACDelco-20880895-Equipment-Automatic-Transmission/dp/B0049417FU
The regular one appears to be ACDELCO 52497562
https://www.amazon.com/ACDelco-52497562-Equipment-Automatic-Transmission/dp/B000C9TO5Q
I will say that for nearly all my towing, the heavy duty cooler did fine. It was just in the extremes like climbing up the Coq. did things struggle.
However, I do like that you were able to keep the AC running. On the Coq our engine temperatures were going a little above 212 at which point I turned the AC off and the heat on. You DO NOT want to have any sort of breakdown on the Coq. If you do a street view, you will see there is no place to pull over at all. At least the California Grapevine has more places to pull over.
Anyway, thanks, I now have some perspective. I'm quite surprised that keeping transmission temperatures down helped out that much with engine temperatures.
No there is plenty of air at 60 mph....
I know your probably right, but it is "preheating" the air to the condensor. Im way over thinking this! But we live in the upper mojave and in the summer 110 is a normal day!
