A/C in the rear isnt working.....
Chads93GT
St. Louis, MO
01 tahoe. 2 years ago my compressor went bad and I never got it fixed due to the cost, and not caring. Last week I blasted a deer and damaged the condensor/etc so I figured I may as well get the AC fixed since there was a charge on the bill for the cost of the ac discharge/refill/etc.
It now works, my front end looks brand new, and I have AC again, BUT..............the rear AC doesnt blow cold air like the front. Ive put it on auto, rear control, even hit those 2 buttons up front under the fan speed that have the picture of the truck with the arrow going into it, and the one with the arrow looping around inside of it.
One thing to note, a couple years ago that fan block above my head in the drivers seat, with the small grill cover, was making an awful howling all the time. I unplugged it. I assume this had something to do with the 'computer control' of the climate, so i just plugged it back in. Its not making any noise, and its spinning away. What is this damn block for anyway?
Anyway, I got hammered hard core in the ass end last year on I55 in St. Louis as i was stopped in a traffic jam, and the traffic coming up behind me didnt realize the traffic was stopped, till it was too late. When the body shop fixed my truck, they of course had to remove the rear HVAC stuff, and reinstall it. they said when they went to recharge the AC, it was blowing the freeon out of the front of the compressor, duh. I knew that it was bad.
Anyway, is there something I need to check somewhere to see why the rear AC isnt working? Is it possible they disconnected the AC line running to the back? I guess I need to pull the interior panel out to find out? Anyone know any of the answers to the questions.
C
Chads93GT
St. Louis, MO
Thanks for the hard hitting tech guys. At least I know where to come when I want to know how to install HID's, remove a roof rack, throw on some 22's and lower my vehicle.
road1will
pretty pretty good
Johns Creek, Georgia
Chill out dude - give people more than a day to respond to you.
Or here's a better idea, instead of asking others to solve your problem for you, how about you open it up and figure it out. Then you can write all the "hard hitting tech" about it that you want.
C
Chads93GT
St. Louis, MO
Yeah I will just crack the AC lines open and just start replacing actuators and components hoping that will solv e the problem. Im obviously looking for people who have ran into this problem before. If it were a drivetrain problem I wouldn't be on here, i would bei nt he garage doing. Climate control systems are a bit harder to diagnore, hence looking for someone with a tahoe/yukon/escalade/suburban who has had the rear AC stop working.
BOSS
The People's A D M I N
Dallas
That's REALLY gonna get some guys to help you out. Sheesh
I would just chill, bump the post and see if that helps get some attention to the thread when the technical guy(s) are online.
BOSS
---------- Post added at 08:20 AM ---------- Previous post was at 08:13 AM ----------
Could be your actuator? Does the heat work?
This is what I found by googlling:
http://chevroletforum.com/forum/archive/index.php/t-10976.html
BOSS
road1will
pretty pretty good
who told you to go start randomly replacing shit? Did you even read my post?
I know a bit about AC systems and could have given you some pointers about diagnosing the problem.
In the meantime, how about you go answer some other users tech questions and hit us with your oh-so hard hitting tech.
BOSS
Dallas
"might be a plugged expansion valve"
http://www.2carpros.com/forum/2002-chevy-tahoe--rear-air-conditioning-vt151345.html
"might be a blown fuse"
http://wiki.answers.com/Q/Why_would_your_rear_AC_blower_quit_working_on_a_2003_Suburban
BOSS
---------- Post added at 08:33 AM ---------- Previous post was at 08:28 AM ----------
This is from a 2002 model but I think it still applies to the 01
"There is only one compressor. The good news is that the a/c system should be working fine if you get cold air in the front system.
For 2002, there are manual and automatic controls for the rear system. The manual system is simply a potentiometer that provides a voltage between battery and ground to the temperature door motor. Look for a wire that has rubbed against a bracket and shorted to ground.
The automatic system uses an infrared sensor to determine the temperature in the rear seating areas. This could be messed up. There should be a manual mode to allow you to determine if the control head works at all, the IR sensor is bad, or if the head is fine. Set the system to manual and try moving the temp knob. If it doesn't move, look for a shorted wire to the temp motor. Or measure the voltage at the motor to see if it changes.
Other possibilities include a stuck temp door.
Good Luck "
http://wiki.answers.com/Q/If_the_fr...the_rear_AC_blows_hot_air_what_is_the_problem
C
Chads93GT
St. Louis, MO
Boss. I know the temp door isn't stuck as I pulled the rear panels off, removed the actuator, moved it by hand and started blowing hot air, then back to air temp air when I turned it back to its original position. The actuator moves back and forth when I turn the temp knobs. I'll try the fuse, and then looked into the expansion valve. Thanks.
Road: I stated, what I stated, becuase in the short life of this forum, the majority of the threads I have read here deal with rims, roof racks, head lights, tail lights, cosmetics, stereo's and other non technical related information. In other words, most of the threads deal more about how the vehicle appears, than how it performs. Step outside the box and look at how that looks to the site as a whole when the majority of the people only know how to modify appearance, but not fix the actual function and performance of the vehicle when its broke.
I came here, because I don't know much about the Tahoe's, and I have one for a work vehicle. My mechanical knowledge comes from 5.0 mustangs from the 80's and early 90's. Ask me anything you want about one of THOSE cars and I could talk your ear off on the subject for days. Ask me something on this vehicle? I simply dont know. Mainly due to having 12 5.0 mustangs in the past 12 years to tinker with, and only 1 tahoe.
Sorry if I came off like a jerk, but sense the frustration when you come to a site all about a vehicle...........and there isn't anything tech related that helps, with the search feature.
PavementPounder
Cincinnati
when i get to work I will as one of my hard hitting techs and see what they think.
---------- Post added at 01:26 PM ---------- Previous post was at 01:25 PM ----------
don't forget this site is fairly new and we are working on getting stuff in here from forums past.
BOSS
Dallas
Good news is the front a/c works ;-)
I barely knew how to modify appearance before I got here....those technical guys are here and there on this site and others, we're new so give it time and bumps...you'll get your answer.
Stick around, help us out!
Stick around then, help us out!
No worries man, like Forrest Gump says,
"It Happens."
BOSSMAN
C
Chads93GT
St. Louis, MO
What irks me the most is this chiltons manual i bought when I got the vehicle a few years and 200k miles ago, this thing has NOTHING about the rear AC in it. Seriouly, what the hell> i know these manuals such as this are pretty much useless and good for general pointers at best, but this one isnt even that much help. The ford service manual for my 93 GT was $120, id hate to think what the manual for this thing would cost.......
BOSS
Dallas
Hey bro, you figure the ac issue out?
BOSS
RahRah
Well just in case it helps anyone someone talked about their foot on the driver side calling the rear AC to come back home and start working. Well I don't know what I did but I pulled the panel off right there where the hood release switches and pulled the carpet back messed with some wires and it started working.
JamesinAbilene
