Hey guys, I’m here stuck in my truck on the side of the road so any input is greatly appreciated. I’m 4 miles from my mechanic, so I’m wondering if I can just drive it...
Anyway, The coolant is right at the fill line, however I noticed I had vac lock when I tried to unscrew the cap.
As I was driving I noticed I had to give it more gas just to keep maintaining speed. I guess that’s power loss?
The temperature gauge never went passed a tick under 210.
what I found weird is that even if I put it in neutral the truck slows down very quickly. I’m wondering if there’s a brake stuck or something?
The previous owner remove the parking brake, so there’s nothing that should be stopping it in that sense.
I check the tranny fluid and it’s still red, so at least there’s fluid in there. Obviously could be a transmission issue that I wouldn’t be able to see from the fluid.
but what would cause the truck to still have so much resistance, even if I pulled it out of gear?
I have to give it a bit of gas to get it to go in reverse, it rolls forward easier. But even still there’s no coasting at all.
could it have to do with the brakes needing to be bled?
Yesterday I pulled up to my buddies house and basically had the same issue. That’s when I popped off the coolant cap, replaced it, sat around for a few cold ones, and it rolled home nice and smooth. Granted, that was only about a mile home.
I appreciate any insights, as I know very little about troubleshooting these things.
