thehoe92 Lowered 3/5
thehoe92
thehoe92
fo sho
The916
as soon as it happened I remembered when I was texting you about it and you said "come to think of it I didn't do anything, it ripped down... THEN I could cut it"
I just beat it back into place for the time being
well got my alignment today
my steering wheel is no longer crooked while driving straight
the height was not effected (Blizzard)
I started with close to -4º camber and now its down to -2.2º
the Les Schwab guy struggled with it but he got it pretty close to spec
it drives a lot smoother now
I did notice today.. I looked underneath the front end and even though I had trimmed my bump stops one notch they are still smashed to the frame
is there a free travel mod for the front lol?
Max
Mile High
Denver
The front stops are normal, GM calls them jounce stops though some bilsteins would help the ride quality:
^^^holy grail of dropped ifs torsion bar trucks^^^
thehoe92
thehoe92
fo sho
The916
I've got the Belltech Toxic Drop 2 shocks up front and it already is better than stock but I would LOVE to have bilsteins front and back
Blizzard was tellin me about the Z71 stops.. how are they different?
Max
Mile High
Denver
The z71 stops protrude out at the top giving it a bit of a pre-bumpstop. The bilsteins pictured above have an integrated bumpstop on the shaft which really smoothed my truck out, now I just have to notch the rear frame to get the ride quality back on that end.
thehoe92
thehoe92
fo sho
The916
realized that right after I typed it lmao whoops!
the bump stops are still smashed in the front but for some reason after the alignment it rides better
same ride height but I feel like I have more travel now
Max
Mile High
Denver
Factory height bilstein HDs work with shock extensions up to a 5" drop, I'm looking at the 5100 series 18.5" extended length part # BE5-6251-H5 for my truck with a 7ish spring.
slammedcavi
So, from what I am understanding, the regular bilstein HDs are shorter and ride better than the factory air rides on the denali? part # how much shorter are they? Thankls
Max
Mile High
Denver
They're about an inch shorter which is why you have to use the shock extensions. Part # on the stock rear HDs are BE5-E380-H0.
Travieso
Boooooooost !
Los Skandeles, CA
i could only type from my experience but i love my belltech street performance shocks, hey kasey how low is the hoe now ? do you get measurements? I recently dropped mine more in the front im sitting at 32 1/2 in the front
skyhighsami
Ok, I just read over this and this is the problem I am having. My wife's truck (2wd Yukon XL) is lowered 3-5 with 305/40/22s. It rides like crap, according to Tony I have the HD rear coils so I am going to get new coils but what shocks would make this truck ride super smooth? I LOVE lowered trucks (obviously 6-8 wasn't low enough on my dually) but my wife isn't happy and I hate driving the truck because there is 0 compression in the rear and the front is very stiff. It has the DJM (Toxic I guess) shocks now.....please help because the truck will look stupid stock height and I think that will be it's direction if I can't make it ride better.
Travieso
Boooooooost !
Los Skandeles, CA
These are the mods that i did to finally get the ride riding smooth
Suspension Mods:
3/4 Ton Chevy Stock Torsion Keys in Front 1" to 3" Lower
AIR LIFT 1000 Series Rear Air Spring Helper Bag Kit #60769
Belltech Street Performance Rear Shocks
Belltech Street Performance Front Shocks
DJM 5" Rear Coil Springs
Z71 Front Bump Stops
DJM Rear 3/4" Urethane Rear Bump Stops
DJM Free Travel Mod
Eibach Front & Rear Sway Bars
McGaughy's 2" Drop Spindles
KYB Steering Stabilizers shock
The Most improvement overall i gotta say out of everything was the DJM free Travel Mode done and The Aftermarket Keys that made night/day difference for me
thehoe92
thehoe92
fo sho
The916
well lets see if I can hit everyones points
its between bilsteins and street performance belltechs right now
max you love your bilsteins and I have heard great reviews so I almost want to right out of the gate start with bilsteins then later down the road upgrade the front shocks to bilsteins as well instead of buying the belltechs and then switching, ya feel me?
IIRC I am right about at 32 1/2 as well, I don't care to measure the back because its not done yet but the front is done might even lift the drivers side a little more because I sliced the shit out of my tire all the way around without knowing it
ride quality for me..
back is belltech progressive springs, shock extenders, stock shocks, bump stops taken out but the bump stop bracket is still in and it rides cool, not bouncy not stiff but it could be better
front when I loosened stock keys on stock shocks it was stiff because it was bottoming out to much and loosening stock keys isn't always the best idea
phase 2 I installed drop shocks (belltech drop 2 shocks) and sliced one notch off the bump stops, still stock keys all the way loose and it rode like a dream, seemed to just take the bumps with ease, curbs felt nice
phase 3 I installed the lowering keys and have them almost all the way loose and its right about at stock again because it is smashing the shit out of the bump stops right now
I'd say buy some belltech shocks and some shock extenders and you'll notice a significant difference also as stated above bump stops/bump stop bracket makes a HUGE difference
before I took out my bump stops in the back I would bottom out on WOT never realized I was until I took them out
skyhighsami
Ok, today at lunch I looked at it. The shock extenders are on and the free travel mod has been done. Tony called and said I have the blue DJM coils and they are the correct ones. So what shocks should I buy and what coils should I try? Or will better shocks smooth it out? Right now I have 5" DJM rear coils.
skyhighsami
Suspension Mods:
DJM Free Travel Mod
Ok, I have some questions about this. Right now I have 3" DJM lower control arms on my Yukon, will I need keys if I don't want to be any lower? With the 3" control arms I have alot of adjustment left on the torsion keys but would adding some from a 3/4 ton help soften the ride any? How much did the Air Lift 1000 help with the ride? I understand it keeps from bottoming out but doesn't it soften the ride? How much did the front bumpstops help as well? Would replacing all the shocks with Bilsteins be good enough or should I do what is listed above or just purchase this http://www.summitracing.com/parts/ART-ARR22100/ How much of a difference did the Eibach sway bars make and any reason to get them over any other brand? What about aftermarket trailing arms, are they needed on these trucks? I know I am asking alot of questions but I realized I don't really know anything about these trucks and the "kit" I got from DJM isn't as well engineered as I thought.
matt14
san leandro,ca
I dont think adding some keys is going to make a difference. What front shocks are you running? I had the stock shocks becase when i bought the kit off styin trukcs ( before i knew tony was a djm vendor), they said that the stock shocks work fine, and they dont. you have to run drop shocks in the front. Did you trim the front bump stop at all? You could be bottoming out if you diddnt. As far as the rear goes, mine rides stiff, but not bouncy. Its more solid then anything. I am running djm drop shocks all the way around, but have been thinking about trying out some bilstiens with shock extenders for the rear. Just to try and get the ride a little better. Oh yea, i am running the same djm 3/5 kit
skyhighsami
I too am running the DJM shocks all the way around. The rear of mine is very stiff in fact harsh so I want to do something to smooth it out. Even if that means getting the bag kit for the back from Ride Tech and running Bilsteins up front.
matt14
san leandro,ca
Did you do the sway bar end links on it with the djm ones and actually relocate them? When i did mine, i diddnt read the directions and just put it in. I diddnt relocate the sway bar mounts like they said the the sway bar was hitting the panhard bar. Check this, it rode horrible
johnsonwillie199
