3rd Row subwoofer.
Daking602
Northern Nevada
Here is my set up. 3 12" JL Audio W3. I'm taking it out and putting in 2 12" Alpine Type R this week.
NASTY GM
Nor Cal
I removed my third row for three 12" JL's
Fauxnali
Gold Member
Edmonton Alberta Canada
I've got the two 12"W7s in the back and no third row and the wife uses it as a grocery getter, but we have the two little ones and if they each have a friend over we'll need that third row so I'm thinking of going down to one and at least put half the rear split seat back in. I can always through the other one in my '85 5.0. Each one is powered by a JL 1000/1 mounted on the box and it takes a lot to remove the box with both subs and the amps mounted to it, it's gotta weigh 300-350 pounds so any removal has to carefully planned.
puckhead
CO
I dont know if everyone uses the whole third row (I dont). so I only used half the third row and can still use the other half for a nice set up. By buddy likes sitting back there so he can get blasted by the subs lol. just a thought!
JDTAHOE2001
HOUSTON
They have a box that can fit underneath the 2nd row. It only holds 2 10" but you'll be able to keep your 3r row
Fauxnali
Gold Member
So I pulled my subs and now am in the process of designing a ported box for one sub to go behind the third row. I have a couple of issues with that as in I don"t do fiber glass and I don"t want it to stick up over the rear seats when they are folded down. I have done some rough measurements and I should have the box volume to go ported as long as I stick to one sub. As soon as I have a design finalized I will post it and I'll post pics once it's installed as well.
I want it down facing so i can throw stuff on top of the box with out wrecking anything as well.
Seng619
All these mods are great. So it comes down to money and the layout you want.
CHINO07KON
MIAMI
I'm having mines built since Wednesday..It is similar to 1SIKYUKON but my speakers will face each other with ports up top and plexi to show the speakers..Im only doing 2 Kicker CVX 10"s with an Mmat 1600.1..Well more than enough for me..If done right it should pound harder than 12's
Fauxnali
Gold Member
Behind the third row or where the third row is supposed to be. Check my album to see two 12W7s in a ported box where the third row is supposed to be. I took it out and am in the process of drawing up and building a box to fit one ported 12W7 firing down so i can keep it level with the third row laid down and still pile stuff on top of it with out wrecking the sub.
BCA
Cali,High Desert
I would have done something like that if i didn't need the third row but mine sits right behind it and the amp sits under the second row so its a clean setup.Now though i actually wish i would have got a burban or a XL Denali
Drewphil
