Nyjetfan21
- Joined
- Jan 31, 2015
- Posts
- 94
- Reaction score
- 2
I’m a little confused on what the RPO code means also the way I explained to you about the actuator for my truck which one would you purchase
PASSLOCK(TM) SENSOR
The Passlock(TM) sensor is inside the ignition cylinder lock housing. The Passlock(TM) sensor contains 2 hall effect sensors. The tamper hall effect sensor is on the top. The security hall effect sensor is under the tamper hall effect sensor. Both of the hall effect sensors monitor the magnet of the lock cylinder through an opening. The tamper hall effect sensor is physically placed on top of the security hall effect sensor. This arrangement enables the tamper hall effect sensor to engage first if an intruder attempts to bypass the Passlock(TM) sensor by placing a large magnet around that area of the steering column. There is a tamper resistor inside the Passlock(TM) sensor in order to help prevent tamper to the system. Passlock(TM) equipped vehicles have a selection of 10 different security resistors ranging from 0.5K ohms up to 13.6K ohms . Installing one of the security resistors inside the Passlock(TM) sensor will generate a unique Passlock(TM) code. All 10 combinations of the Passlock(TM) sensor have the same part number. However, you cannot simply replace the Passlock(TM) sensor and expect the system to operate properly. Always start by performing the Diagnostic System Check first and following the instructions.
It doesn't sound to me like it's a problem with the actuator, it sounds like you have something manually preventing the lock from opening. Have you tried having someone pushing the door in from the outside while attempting to force the manual lock slide inside to move?
Or maybe push on the door while trying to operate the key in the cylinder?
If there is something in the latch mechanism or between the door and the frame putting pressure on the latch mechanism it is possible that that might make it bind to where the lock cannot be disengaged.
I never I actually tried what you said to push on the door from the outside and have somebody try to engage the lock but let me ask a simple question would it affect all the locks if it had something to do with inside the ignition because it’s only affecting the passenger front door and when I pull the slide off I can get a pair of pliers on the rod and pull it To open the door but there is a lot of tension behind it
Service and Repair
Binding Lock Cylinders
In many cases, applying the proper lubrication can correct the following conditions:
For lubricating the above components, use lubricant GM P/N 12346241 or equivalent
- Binding or sticking door lock cylinders
- Difficulty in inserting and removing the keys
Do not use penetrating lubricants such as GM P/N 1052949 or WD-40(R). Penetrating lubricants wash out the original lubrication. Penetrating lubricants eventually evaporate, leaving little or no lubricating material. However, when using penetrating lubricants in order to thaw or in order to loosen the lock cylinder components, refer to steps 2-4 in the procedure below for the proper methods of lubrication.
Repair lock cylinders frozen in cold weather by using the following procedure:
- While carefully avoiding damage to the painted surfaces, apply heat to the cylinder with a heat gun.
- Using a paper clip or a similar item, hold the door shutter open. Force air into the cylinders using compressed air through a blow gun attachment.
- While holding the shutter door open, inject small amounts of a recommended lubricant into the cylinder.
- Work the key into the cylinder repeatedly. Wipe away any excess lubrication from the key.
