Interesting Issue
Bailey-Hoe!
Vermont
So, when bought my 04 Hoe LT, the driver's power seat function was a little screwy. When you go to adjust it, pushing it forward moves the seat backwards, and vice versa. Therefore, when I set my preference for easy entry on activating the unlock button, it actually works in reverse and slams the seat to the steering wheel. Obviously being 6'2'' and extremely handsome, this is bad.
Not sure how this happened as I am not the original owner but was hoping that reversing some wires or something, I could get it back to normal. Any thoughts?
puckhead
CO
Love this quote! lol its goin in my sig!
That is really strange though. I dunno if unhooking your batter for a while would do anything either. Does it look like they messed with the cover on the seat controls at all?
wjjeeper
Edmonton Alberta
You're missing your flux capacitor.
Easy test - head out on the road and go 88 miles per hour. If nothing short of spectacular happens i.e, time travel, then thats what it is.
puckhead
CO
You gonna post this on all the threads you visit?
gmcjohn
This may sound stupid, but just get rid of the driver settings because that sounds like a complicated problem. Then just take the switch out, flip it over and put it back in, that way your seat will go where its supposed to when you push the bottons.. lol :)
slocaddy
sarasota fl
Im the second owner of an 03 escalade that doese the same thing. Not only the front to back but also up/down tilt on the front cushion. Thought i was gonna die when the easy exit function began to crush the life outta me. we dont do that anymore.
HMFDZ28
Hunt Sta, NY
My '06 Hoe did this too... I set the seat all the way back and programed the setting just like the 1/2 button preferences... Now it doesnt try and kill me lol. I am also a small lad at 6'4" and have been compared to bathrooms made of brick lol.
Bailey-Hoe!
Bailey-Hoe!
Vermont
There has got to be something here. Why would it start doing this?
my09denali
my 03 Z71 did that too all of a sudden one day. i know it had something to do w/ the battery. but i can't remember if it was when it died or if it was when i took it to the dealer and they had unhooked it for something they did. the only one that was backwards on mine was the front/back.
Bailey-Hoe!
Bailey-Hoe!
Vermont
I took mine apart. there is a whole module that the adjustment switches connect to. There is also a wire harness. I like th idea of switching a wire or two but that seems like a band aid on a problem.
Could it be a programming issue? We must solve this.
BOSS
The People's A D M I N
Dallas
I would just reverse the wires...break out a solder gun and get to work bro :waytogo:
I am no electrical guy to save my life but it really sounds like wires are reversed...the production line soldering machine in the factory could have had a hangover that day
B
Bailey-Hoe!
Bailey-Hoe!
Vermont
B
I thought that too. However, if you take off the seat plastic planel and expose the adjustment switches, you will see that it is a control module.(hard to get into) and a wire harness. I was hoping for a few simple wires but there are like 10 of them in the harness.
The weird thing is, I am not sure it always did this.....but instead just started one day. What I might do is take off the passenger side, they are structurally mirror images so I won't be able to mount it permanently. I can use to test it. What a pain.
Best case is I trace the wires back to the motor and then do a switch.
Worst case is to replace control module.
If I go digging again I'll snap a few pics. Getting 20" of snow right now.
BB
JamesinAbilene
