Another heated seat question
Artie16
2011 Yukon denali
drivers heated and cooled seat do not work. pass side works fine. switch lights up and stays on. checked connectors/fuses/relays. any ideas where to go next?
Artie16
Artie16
One of the main reasons for this is a connector under the front of the passenger seat. If you unplug it, you will see pins burnt up if that is your issue.
checked all the connectors under both seats, no burnt pins. Checked for codes, no seat codes at all. guess I'm pulling the seats apart this weekend
Multnomah Falls
Military
Just like I would have to do, if you have not done that before, watch you tube for help and watch 2-3 of them if you can. They are not always the same and some will show a "work smart not hard" way to do it.
mikeyss
Longmont, Colorado.
When mine acted up, the passenger seat would not move forward or backward. There was a connector on the floor by rear of passenger front seat. I had loose terminals in that connector too
I now have a bad TED under the driver's seat. Only the seat back warms but if I try to run the bottom too, it trips the system.
Artie16
Artie16
UPDATE
disconnected the door terminal in the fuse block, cleaned it and reconnected it. AC seat fan now comes on and heated seat relay clicks now, but still no heat
CB12
