Senor_gregmtz
- Joined
- Oct 19, 2015
- Posts
- 10
- Reaction score
- 1
Need help guys i have a 02 tahoe question is what could be going wrong truck when its runing on freeway it waves like im on a boat
What exactly do you mean? It wallows--side to side? Up and down?Need help guys i have a 02 tahoe question is what could be going wrong truck when its runing on freeway it waves like im on a boat
Yes wallows side to side i had check my sway bar links but they look good so farWhat exactly do you mean? It wallows--side to side? Up and down?
Had that happen in a caddy years ago--it was either the idler or pitman arm(forgot which one). Replaced it and no more side to side.Yes wallows side to side i had check my sway bar links but they look good so far
Yes im going next whit the shocks do you think it could also be the storcion bar that it could be lose at some point just got the this truck and it looks like they dropp it a bit ?I would look at sway bar links and shocks at first glance.
But did it feel like a wavie ride like if you were in a boat ?.. I'm gona check that thank you for your helpHad that happen in a caddy years ago--it was either the idler or pitman arm(forgot which one). Replaced it and no more side to side.
I already check all ball joint and bushings from control arms ..they look good also check control arms ..What have you checked so far?
Actually did, especially if I hit a dip or bump.But did it feel like a wavie ride like if you were in a boat ?.. I'm gona check that thank you for your help
Oh ok yup its exactly what going on with mine thanks gonna do that and check it out this afternoon hopefully that would be the problem and get ti done with thumbs up man ..thanks againActually did, especially if I hit a dip or bump.
You had a Typhoon?Ditto idler arm, you can imagine how disconcerning that would be when the turbo spooled up in an all wheel drive typhoon.
Yes, had lots of fun in that truck.You had a Typhoon?
Oh yes--same here. Mine was teal.Yes, had lots of fun in that truck.
I was many years ago. Been so long I don't remember what # mine was.Mine was white, #888. Were you ever in the sy-ty groups?
