Bryingram4
I shelved the drop kit and 24’s and went with 5” Lift w/ 35’s. Rides better than new!!!
I shelved the drop kit and 24’s and went with 5” Lift w/ 35’s. Rides better than new!!!![]()
Thank you.Looks really good man.
What size rims?
Any trimming required up front for clearance?
Did you have to over-ride the factory MRC? If so, what’d you use to do that?
Those look awesome after job completed, can you show some pics.Installing Brembo GT right now
I need one of those for my 18 Silverado it's lowered and scrapes on practically anythingReplaced the stock airdam/ spoiler with the much shorter PPV version.View attachment 232919 View attachment 232920
I would have to draw a straight line with something, my experience has been that the plastic just pretty much melts also
ya that's what I was thinking, I just need to measure a basic sidewalk height and then add about 1/2" to that and then measure from the ground up on the valance on each end and then make a line across, maybe use some fishing line and then mark it with a black marker.^ yup
you could use 2 people, string & tape to mark it off. mark it a little long, so its easier to clean up the line after.
much cheaper than the PPV version
I feel kind of stupid now I was looking at it again yesterday and realized there is a extra bottom piece screwed on that I can just take off and it should give me just enough clearance.I used a reciprocating saw on mine. Used the topmost bend as my main line and extended it to the edge with painters tape, marked, cut then ran a pair of needle nose pliers along the cut to scape the debris and clean up any burrs. Turned out nice and just gave me a whole lot of ground clearance without a lift. Looks identical to a PPV w/o the cost.
hmm, I haven't looked at it that close yet I just was walking up to it in the parking lot and saw the line across and I thought hell I can just follow the line then as I got closer I realized it was a separate piece I stuck my hand under and felt a bolt on the outside edge, I'll check it out todayMine as well, but in order to unscrew it on a 2017 model, the entire nose needs to be removed as many of the screw heads are otherwise inaccessible. After several options were attempted, I chose the option requiring least effort mentioned above.
