Hard to pump gas
HACK BLOCK
NYC
2011 yukon denali just started give me a hard time pumping the gas stopping every few seconds. I know it could be a clogged vent but I don't know where it is or how to get to it. I never looked under the truck so not sure what I'm looking at
Try a different pump before blaming your truck.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Like avalonandl said, Google is your friend and you are likely spot on with the vent problem. Has the tank been dropped recently?
Nap73
This happened to me 2 days before my fuel pump took a Sh#% on my 04 Yukon. Have no idea if this is some kind of “tell” forecasting that.
Randy Whistler
Living the dream! I'm just not sure who's dream
In Hell, but I've got a Tahoe!
My daughter had a Kia SUV that had a similar problem, and it was a filter or vent hose of some type, though I can't remember which now. I'd say that's as good a place as any to start looking, but like you, I'm not sure where to look on your rig.
Derick
Indy Suburbs
Try backing the nozzle out of the tank about an inch. I notice that if I jam it all the way in there, it pops off after it starts fully flowing.
H
HACK BLOCK
NYC
that's how I been filling it up but takes forever
Da90
Tulsa, OK
When I had this problem with our 2009 it was the charcoal canister.
rd62rdstr
Tucson, Az
I have had the same problem with some pumps at gas stations here in California due to their vapor lock systems on the nozzle. I found that other pumps from different gas stations do not cause this and I don’t have the problem in other states where they don’t use the vapor lock nozzles.
Denali12
Curious why you ask if the tanks was dropped? I recently had the tank dropped in my 12 Yukon Denali at the dealer to replace the fuel pump module & have been having a hard time filling up since. It is progressively gettin worse. Dealer did a visual inspection & stated "everything" looks like it should.
The reason I asked is because when the tank is dropped and then reinstalled, sometimes the tech will kink or route a hose wrong where it can be pinched during the reassembly process causing vent problems. If the problem did not start till right after the tank drop then I would suspect the problem could be related. I have seen it in shops I ran before, especially when the original shop "took a look at their work" and said they saw no problem. They could also have damaged some of the vent parts back there unknowingly.
mountie
My '05 Yukon..... Some gas pumps have a stronger flow..... It has happened to me once in a while.
I slow the gun a bit and the problem pump fills ok....
Maybe try a different station and see if there is a different result.
SuffolkD
2007 5.3 Yukon mine kicks off when I keep the engine running at fill up
Turn off and the issue disappears
Replaced charcoal canister and tube 100K ago
328K now.
SuffolkD
Engine turned off when re-fueling?
varminpoolteam
