Pro Comp 2.25” level
Bwiggins1985
Hi guys! Just got my suburban this last week and I put on my 2.25” pro comp level this weekend! It’s a little bit higher in the front so I am going to ad a spacer in the rear to give it a little bit of rake back. I ended up putting 285/70R17 Roadcurza RA-3200 MT. They look really good! They have a little bit of a humm at 50-60 ish and a little around 70...the seem to be quieter around 78-80. Texas freeways 80 mph :-D I am thinking I am going to put some spacers to push the wheels out a bit unless I can find some wheels with a good offset for a good price. Might go with chrome but not sure yet. I also found a scratch and dent grill guard it’s stainless/chrome so that’s what I am thinking to try for chrome wheels. Sorry I didn’t get any before pictures....
B
Bwiggins1985
I made a trip to San Antonio this weekend and the MTs are just too loud. Going to have to switch them out for an all terrain...
B
Bwiggins1985
I also got some measurements today in the driveway and for some reason the passenger rear was about 1 inch higher than the rest of the truck. I am going to measure again tomorrow in a parking lot or a garage. The other 3 were real close to 38” from the ground to the wheel well. I am thinking it might be my driveway because it kind of turns and is on an incline.
Driver front
Driver rear
Passenger rear
Passenger front
B
Bwiggins1985
So its been a year running my pro comp level with the Toyo AT tires. And it was time to replace the struts and shocks. SO I ended up getting Bilstien 5100 struts and Skyjacker lifted rear shocks. I also picked up a set of Z71 rear coils and a rear spacer. Thus far I have installed the front which turned out to be a chore to say the least. But once I had all the tools it really wasn't that bad. Here is the story in picture lol...
Friday night I went to a local shop and swapped out my Toyo AT tires for these. Kanati Trail Hog AT LT305/70R17 tires. They fit but I am going to have to install spacers to push them out a bit. I had bought some spacers but the studs are the wrong size so I will have to get some different ones. Might have to do a tiny bit of trimming after the additional lift. Truck was naked!!!
This last weekend after my daughters birthday party in the ridiculous hotness of Texas I started taking apart the front to replace the front struts. We had the lights set up, the tool out, the fans going...ready! Get the truck jacked up and on stands...get the strut tower out of the truck...put it in the rental tool strut compressor and start going to town...BOOM tool breaks. And this was awesome because it broke with my spring compressed enough to get the strut out. I was able to get the strut out but it was an ordeal because I didn't realize you need a special tool to hold the strut shaft still while you loosen the top nut. Tried it without any other tools and the strut rod kept spinning. Then I tried an impact wrench and nothing. I ended up having to tear the foam/rubber boot around the top of the strut and hold the shaft with vice grips. With that I got the old strut out. Now to deal with this compressed loaded spring in the broken spring press. I ended up behind something with the spring in the tool pointed away from everyone knocking it out with a rubber mallet. Probably not the safest but it worked. And that was the end of night one.
B
Bwiggins1985
Here are the pictures of the tires installed. I couldn't upload them to the above post.
B
Bwiggins1985
Okay, back to the ordeal of installing the Bilstein Struts. As the picture above shows...Sunday morning I just have my truck with the driver wheel well just hanging out there... I ended up taking the broken tool back and rented 2 sets of strut compressors. I got home and started compressing the factory spring. It was a lot stronger than I thought it would be. I had to use my breaker bar to get it down enough to install the strut into the assembly. I had it on my kitchen table since it was so hot outside. Worked pretty well with 2 ratchet straps holding the assembly down on the table.
So I get ready to install the top nut to the 19 FtLbs the instructions call for and like the factory struts the rod just sat there and spins...tried the impact wrench and it still spinning. So once again I am stuck. I start researching and you need a special strut install tool. Basically its a nut drive that goes over the strut stud, these have an oval head while some have an Allan head slot, and then a larger nut driver that tightens down the top flange nut while holding the strut rod still. Had to drive across town to find it. it was the only one in town...
So I get it torqued down and outside I go. Only to find out I installed the strut in the spring backwards... Back we go to the table to strap down the assembly and spin the strut 180 degrees....lol
Back outside it went into the bucket very easy. Used the impact wrench to install the bottom strut bolts through the lift, and used the impact on the sway bar end link, and the tie rod end. Had to jack up the lower control arm and pry the upper control arm down to seat the ball joint. With it pried down you can tighten the ball joint nut without it moving. You have to use an impact wrench on the tie rod end or the ball joint in it will spin.
By this time its like 5 pm. I hurry to the other side and repeat the process. It only took about an hour for the other side. This one was a little difficult to hold the strut rod still even with the vice grips. I had to hold the strut rod with vice grips which I almost couldn't close, and use the impact wrench to spin the top nut off fast enough. Everything is put together and looks really high in the front compared to what is use to be. I am really liking it. I will definitely have to get new upper control arms. There is about 3/8 to 1/2" clearance between the control arm and the stop. I will probably do that over the next few weekends. I need to install the rear now and get different wheel spacers and do the alignment. I think its going to look sick when I am done with it! I will get some pictures of the front on flat ground sometime this week!
wjburken
Eastern Iowa
View attachment 232111 View attachment 232112
View attachment 232113 View attachment 232114
Looks like a job well done despite the challenges. I bet your wife was thrilled with the kitchen table getting used as a workbench! Did the My Little Pony doll help with it's magic?
R3cord303
Posse In Effect
Oregon Valley
After using spring compressors on my old S10 to change the worn out LCA bushings- never again. Not a freaking chance in hell I'm ever gonna use em. Wall mounted ones- maybe but not ever the kind that hang out on the strut itself. Sooooo much energy held back, screw. that.
The_Burban
Nice work . I just did Z71 springs with Bilstein 5100s. I'm not brave or dumb enough to do that spring compressor like you did.
No shame about installing wrong. Mechanic I handed them off to Did the same. Another broke the strut.
B
Bwiggins1985
It was more of a WTF moment lol...and Ughhhhh....
I went ahead and ordered upper control arms this week to install this weekend.
I was a little nervous about using the spring compressor but I figured what the heck... and that’s why I figured 2 sets so 4 bolts. And my thoughts were if anything were to come loose it wouldn’t go far as it was strapped down.
Has anyone seen a failure with these tools? In theory the bolts could break or the hooks could slip or break off. The tool pictured below is the tool I had first and it actually broke and I had to hammer compressed spring out which was kind of freaky... I totally understand the principal of stored kinetic energy.
B
Bwiggins1985
This is what I did last night after I started having a misfire on the drive to the airport on the way out of town last week... yay... I am not sure if these are the original plugs or not... I think I am going to replace the ignition coils and the wires also. It threw code P0301 which was misfire cylinder 1. Really cool side note...since I installed my Kenwood with the Datalink Maestro I could actually check the code and reset it on the radio...instead of going to autozone or etc to get it checked! I started with the odd plugs after cylinder 1 which was gross... (first 3 pics)...then a thunderstorm blew through and I had to come inside per the wife because of the lightning lol.
Came back out a few hours later and tackled the even plugs. Plug 8 wasn’t as bad as everyone makes it out to be. Once I pulled the plug wire off I was able to install the 5/8 spark plug socket onto the plug with my left hand. You can’t install a regular extension for a 3/8 drive ratchet. So I inserted my 1/2 to 3/8 adapter which gave just enough clearance to get past the exhaust manifold. From there I was able to turn the 1/2” drive socket wrench until I was able to click it into the adapter on the spark plug socket and was able to loosen it up. Once loose enough you have to take the wrench off and take the plug out by hand with the adapter and plug socket still attached.
From there you can install the new plug with the plug socket and the adapter by hand until hand tight then turn/slide the 1/2” drive wrench to where you can click it into the adapter-plug socket and tighten the spark plug up. Reinstall the wires...Done!!! It probably took maybe 8 ish minutes for the last plug swap...
Korbin_A
