Crazycrew's 2017 Sierra Mod Thread
Probably not a 16+
Just went back and checked. It's not like yours. I dismissed it as soon as I saw it wasn't a NNBS GMC grille. Shopping for one for a friend.
Your grille looks better than whatever that style is, anyway! Now I gotta go back a page and try to picture it colormatched.
C
crazycrew
Vacherie, LA
So, I still haven't found a tub/container long enough to soak the grill. The large grill surrounding is about 49“. I was thinking an underbed shallow storage container (plastic). I need something shallow so I don't have to buy 8, ******* gallons of muriatic acid, lol.
Also, I wanna do something with the chrome "windows" on my wheels. They're plastic, so powdercoating them is out of the question. I hadn't realized how may different versions of these were available until I actually got them. Most gmc wheels are one color, with no windows. [emoji2369][emoji2369][emoji2369][emoji2369]. Crazy ass gm
Kiddie pool from Dollar General? I know such items are far out of season, but they may still have some floating around their storage.
Throw some bricks in there next to the top and bottom of the grille to take up space and square-off the usable pool area? I'd guess that 4-5 average bricks would replace a gallon of liquid.
Do you need the acid full-strength or can you dilute it with water, like at a 1:4 ratio?
C
crazycrew
Vacherie, LA
Glad I posted this here, lol.
I was told by the guy who had done a few that he uses full strength. I'm sure I can add a little water if I need it just to cover a little bit. I found it at lowes for about $5.5/gal.
Muriatic won’t dissolve bricks or cause them to bleed into the plastic? I wondered about that when I thought of trying this method but it didn’t matter since I never found a container big enough for the Denali grill. I thought about making a frame out of wood and using heavy plastic sheeting to hold the acid.
C
crazycrew
Vacherie, LA
Yeah, not sure about it. May have to use actual cinder blocks, cause the bricks I have are more like a soft clay. The psi washer easily eats em up if not careful
Muriatic acid is commonly used to clean concrete, so it shouldn't dissolve the brick. I guess I should've specified concrete block and not brick, though. In my mind, I was thinking of the stack of gray, solid concrete blocks I have behind my shop. They're about the same size as standard red bricks. Regardless, this is a factor to consider. Or maybe staining the grille wouldn't matter since it's gonna be painted anyway? You just need the acid to etch the chrome so primer and paint will adhere.
But, I do like your idea of making a frame and laying in some plastic. That'd be super easy, cheap, could be made to just the right size and easily disassembled and disposed of or repurposed when done.
Kiddie pools came to mind cuz Dollar General sells them for around $5 and he lives really close to one. lol
C
crazycrew
Vacherie, LA
Some stuff starting to come together!
Conedaddy
