'12 Suburban Retrofit - questions and worklog
headala
Hi, all. Thanks for having me in this forum. I haven't posted much but have benefited tremendously from so much knowledge here. I bet I've read 250+ threads in the last month, since getting my 2012 Suburban...loving it so far.
Except for the headlights. Pretty awful IMHO. The lenses are clear and without oxidation, but they don't put out much more light than our 2008 Sienna with horribly oxidized headlights. Plus I love projects. My wife says that she looks forward to the day when I will buy something without modifying it/upgrading it. Well she'll be waiting a long time I think.
So I plan on doing a relatively standard retrofit, centered on Morimoto D2S 5.0 bi-xenon projectors and 35W ballasts with 5500K bulbs (in the low beam space). In the high-beam spot, I'm putting in the new-ish Profile Hi-Lens LED Projectors. They are kindof an LED cluster with a lens for each LED. Lastly, I plan on putting in each side a 12" Profile Pivot Sequential Switchback strip across the "bar" between the hi/low beams and the DRL/blinkers.
Right now I'm waiting for the parts to arrive before I start. I did have a couple of questions.
How do people usually wire something like a LED strip/halo? I guess I'd like for it to come on with the car. Is that the usual?
Thanks for the help and advice!
The Raven
Fleetwood, PA
Did you get these done? Wanted to see what your experience was with the Profile LED projectors. I used both the Bi-Lens LED (for low) and Hi-Lens LED (for high) in my retro and the results are nothing short of perfect. Got about six months on them now with no issues.
The_Burban
I am using Hikari LEDs for hi and lows.
I like it. I prefer their crisp, white color.
I cannot make any testament to their throw. Not any worse than stock...
headala
headala
Well after a couple of weeks of no replies I quit checking my thread.
I'll try to post some pictures when I get home (I'm in an airport now). The retro is almost done, golly it's been an ordeal. Cutting the frame support to accept the igniter from the projector, then the projector wasn't far enough back in the housing, etc. Added on top of permaseal :banghead:
Permaseal sucks. Looking forward to pics. How did you get them open?
headala
headala
I baked them 300 for 20 minutes, pried a little bit and put some wooden shims in. Then 20 mins more. Rinse, repeat. I ended up doing that for about 4 hours for the pair. They finally came apart, and all the permaseal stuck to the lens side. So then I spent another long date with the oven heating the lens, peeling/scraping off the permaseal, then heating again. This I found 225 to be the ideal temp to let the seal get a little pliable but still will peel off in larger pieces. Sortof.
headala
headala
I saw the pics of your retrofit in the Alpharex thread. Looks like it went pretty well. With the M-LED did you have to cut into your frame?
The Raven
Fleetwood, PA
I didn't use the M-LED, I used the Profile Bi-LED (in the low beam spot). The Profiles have a wider throw than the Morimotos. The M-LEDs have a brighter hotspot but the Profiles are already almost too bright. When I'm cresting a hill oncoming drivers (below the cutoff) get absolutely annihilated.
The clearance issues are another reason I went with the LED projectors...there are no ignitors so there's nothing on the backside to worry about. The retro'ed housings fit with no cutting whatsoever. The biggest thing for me though is the ballasts. The LEDs have no ballasts and as I'm sure you know, ballasts are always the issue with aftermarket HID.
k09viper
