4.8 sierra to 5.3 yukon transmission swap
Mercerbeef
My father in-law got a new truck, wants to scrap his 02 Sierra 4.8 4x4, body’s rotten but the tranny was rebuilt 2 yrs ago. He’s positive the transmission will swap (he’s an old school engine swap guy) with some modifications, floor shifter hi-lo.
My yukon is an 04 4x4 with push button shift hi-lo. Will it work?
not sure what transmission they were putting in the sierra's at the time, but if it is the 4l60 then the 4l80 that is in your yukon is a better transmission already.
I thought only the 2500 Yukon xls came with the 4L80 trans?!
I believe the 03+ yukons, Tahoe's etc should have the 4l80 but I could be wrong just going by memory, I couldn't use anything above a 02 on my 00 without extensive work and it had the crappy 4l60
Should be the same, get the data off the tags on each and compare them, look for differences. Same for transfer cases.
adventurenali92
Big Bear Lake, ca
The Tahoe Yukon and long wheel base trucks all the 4L60E in the 1500 packages. The 6.0 trucks like my Denali XL and the Escalades got the 4L65E trans which is slightly beefier. As far as I’m aware the only SUVs to get the 4l80 trans were the 3/4 ton burbs and Yukon xls.
Still better better than the 4l60, lol
26AT4
