RENAMED!! The adventures of Chase and his 2006 Yukon XL Denali!! Follow along on my travels!
Fosscore
Looks great Chase!! Man, I wish I had any skill at painting..
Nice work Chase!! Sam, go back into his build thread and see before he got coerced on here to do his own little projects...
And now look at his skills.
The little stuff is not too challenging. All in the prep work and taking your time during the painting process. We all get in such a rush between coats and that is where issues usually crop up. lol. You got this.
Light coats, not heavy.
adventurenali92
adventurenali92
Big Bear Lake, ca
Yeah. When I started this build thread you couldn’t pay me to paint anything. I still dislike it, but I’m quite a bit better now then before. And anything detail related is my specialty haha. I’ve got the handle that needed paint curing with fresh paint right now. Should be fully cured in a few days.
Sam Harris
Awesome! One of these days I’ll give it a shot. [emoji16][emoji106]
So I’m starting to tackle paint items. My poor paint is thrashed.... like everywhere.... ugh :banghead:
At any rate @ivin74 sold me three door handles in my exact paint color! Score! But holy crapolla!!! If I’d known how much work it takes to switch out a door handle!! I would not have done it. Anyways, the drivers door handle is in excellent condition as well as the front passenger side handle is great in great shape. Gave them a little clay bar and a little CG V36 polish and they cleaned right up! Then I tackled switching out my driver door handle. It was a nightmare! But I got the swap done(thankfully!)
The factory door handle:
View attachment 228542 View attachment 228543
Pretty scraped and scratched
And the polished up and sealed replacement handle: View attachment 228544 View attachment 228545
I need to repaint my handles, they’re worn on the inside of where you grab them. But with my latest attempt at painting my grill emblem, Im not too sure of my painting skills. Looks like you’re doing good at it though!
adventurenali92
adventurenali92
Big Bear Lake, ca
Yup that’s exactly where my drivers door handle was wearing out. It was driving me bonkers!
Fosscore
How much work is it to pull the handles? I would need to pull them, paint them and reinstall them in 2 days.
For you no issues at all. A couple body plugs, sail panel, handle cover, lock cover, bolt above handle and 3 nuts on the actual handle and release the lock rod. It’s out.
Takes a quick minute to pull the handle part with the spring and 2 plastic pins to separate them.
No worries.
One other screw that gets forgotten is at the very bottom of the panel and faces the ground. It holds the bottom of the panel to the door.
adventurenali92
adventurenali92
Big Bear Lake, ca
No worries.
It was definitely not that easy when I did it lol. My window had to come out otherwise I couldn’t access the handle bolts that bolt it to the door.....
adventurenali92
adventurenali92
Big Bear Lake, ca
I love coming home to big boxes! Lol
I was thinking the same thing, because when the passenger front lock was punched and I tried to remove the handle, I couldn’t get to the bolts. So the glass comes out first, but that’s not too hard right? 2 bolts then rotate it and pull it up? Or is it more complicated?
adventurenali92
adventurenali92
Big Bear Lake, ca
That’s pretty much it. Then just lower the window regulator so you have room to pull the glass and then that also gives you room to get to the door handle bolts. I’ve done it twice now to replace the regulator and for the door handle the other day so o know how to do it. It’s not hard it’s just tedious.
95escahoe
I’ve replaced all of my outer door handles and never had that issue
Drewphil
