Jet throttle body
Eod1
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
Why don't you quote where I got the 1 st and 4th ones already. I dont see it. If you are talking about snake oil. The guy has no experience with it. So not. Or maybe your talking about yours. You just said wouldn't waste your money. Again you gave your opinion with some flash. I didn't think this would turn into a gun fourm with opinions start to turn into delusional fact. Don't worry I will make it easy for everyone. I will buy it in the future. I will polish everything I can polish, heads, intake etc. It will run like a dream. I made the mistake asking for opinions. I won't do it again.:):)
thompsoj22
What are you so pissy about, It is not delusional fact that throttle bodies give little to no return unless they are combined with massive improvements such as forced induction, your question was has anyone bolted one on and liked it? whats wrong with a few experienced opinions that did not reinforce your desire to bolt one on? As you stated, buy it and see for yourself. This forum is one of the best forums i have ever been a part of with an enormous amount of experience. Some of these members have spent thousands of dollars on induction so the your question is posted in the correct forum. Your username should portray "patience" as the first priority, "experience" as the second, and without patience you will never gain experience. Are you assigned to our eod1 here at china lake? Also dont spend to much time polishing your intake. They are smooth from injection molding plastic.
Some of us let others spend the cash to find out something doesn’t add any hp or torque or throttle response. The stock tb has been proven to be perfectly adequate to around 450 hp at which time a bigger one can help. If you’d rather spend money on this part which will net you zero gain, by all means ignore all the information out there from those before you and forge your own expensive trail. Carry on.
kbuskill
NE. FL.
It always makes me laugh when someone poses a question and then gets mad when they don't like the answer they receive... why even bother asking if you already have your mind made up beforehand?... lol
Because he was already going to buy it and wanted us to help justify it even though it can’t be justified. I’m running about 400 HP with a stock TB for instance but he wasn’t interested in those of us NOT using an expensive aftermarket TB with built, even supercharged in my case, LS engines.
Eod1
Eod1
Phoenix Arizona
No not China lake. I don't get along with people well. With what I do normally people don't want to be around me. So I'm use to doing my job along or with my dog. I just have moments where I'm a as$ hole. It's not something I'm born with just learned.
thompsoj22
Fair enough, This is a really experienced forum that you can post just about any question in regard to your GMC and likely get the the correct opinion's or advice to buy the right part the first time and down the road you go!
D Rollins
