Replaced plugs and wires at 76k - 2015 Denali
SuperOldSchool
Hello
Sharing pics of plugs at 76k. Changed wires as well.
Manual states 97,500 miles to do this, but I tend to do routine maintenance early, since I don’t drive in ideal conditions. Waiting until 100k might also make it hard to get plugs out...
They look great. Probably no issues going the full 100k interval.
Rebate going on now for AC Delco 41-114 $3 back per plug. So, from Amazon they end up only $3.39 each.
BMPNUGLS
Mid-MO
They do look pretty clean! Any noticeable difference in performance/mileage etc from the change? I’d be more curious if you found any defects in the wires due to age etc...
SuperOldSchool
SuperOldSchool
I can’t really tell a difference. Maybe a little smoother idle, but I thought that could be placebo effect.
Wires looked fine and I resistance tested one and it was fine.
I really just figured:
1- we don’t drive in ideal textbook conditions, so 100k seems long
2- the longer those plugs stay in there, the harder they can be to remove
3- I’ll never have to do it again, since the longest I’ll keep the truck is to 150-200k (I hope, if it doesn’t fall apart before then)
SuperOldSchool
SuperOldSchool
I take it back about not noticing a difference - idle is smoother now. Used to kinda pulse or shake a little sometimes and that’s gone now.
Maybe it was time in fact....
Bob2C
Northern VA
Was your idle smooth when new and got rough? I have a slight shake at idle and now wondering if plugs have something to do with it. I have 9k miles on the truck and its been a slight bumb at idle, almost like a misfire. Dealer says normal..(of course)
BMPNUGLS
Mid-MO
Try running some SeaFoam and/or Marvel Mystery Oil (see both labels for mixing) with a couple consecutive Premium (93oct) fill ups....doing this every 6-10K miles does wonders for my 6.2 Denali XL. I also spray down the MAF sensor w the proper cleaner (auto parts store) on about the same intervals...
Both my 2015 Suburban and the 2016 Denali seemed to have a rough and/or low idle to me when they were new...but since doing the above they both idle extremely smooth.
Or try this concoction - several people I know mix up this ‘cocktail’ and SWEAR by it!!
gat0r
DFW
re:rough idle... i had a rough idle , but thought it was due to being too low.
in my tune, i had BBP raise up 100 rpm. so it went from 500 to 600 rpm & its nice & smooth now
Bob2C
Northern VA
Mine actually idles when warm below 500. Maybe 450 I am thinking.
SuperOldSchool
SuperOldSchool
It was sometimes a little rough or bumpy when new. Dealer said it was normal and then it actually seemed to smooth out after a while.
I did run Techron cleaner several times over last few years.
I guess it must have creeped back a bit, because it’s really smooth now.
Bode316
I’m thinking about changing mine- 2015 Denali with 65k on them. Not noticing anything different really- I’m like you though, if I change them now I’ll probably never have to do again.
Is there a manual or anything that shows you where all the plugs are located? I’ve never done it before.
SuperOldSchool
SuperOldSchool
You can search YouTube- this may help
Please don’t take this harshly, but if you cannot find the plugs, you maybe shouldn’t be changing them.
Take your time and insure you won’t be rushed. You’ll do fine
Bode316
I don’t take anything harsh- just never changed before- looks easy-
SuperOldSchool
SuperOldSchool
OP with next set of wires and plugs - 172k on truck and 96k on the old wires and plugs.
Took me from 12:30-2:15 start to finish. I did remove the passenger wheel liner again, it’s the best way.
Plugs were not terrible, but it was time. All gapped at .040 except cyl 1 which was tighter at a little more than .030.
Hope to get another 50k out of truck….
BadDaddy2003
