Hit 100K miles, preventive maintenance...?
Johnniev57
Now that I hit 100,000 miles on my 2011 yukon what did you all do for preventive maintenance?
I plan on:
- all fluids changed
- change serp belt
What else did you guys do?
(or is this already covered on another post)
Thanks.
petethepug
Michael
SoCal
Plan for heavy line work on typical failures that can be handled all at once when disassembled.
Look for ...
Oil pan gasket leaks
Rear main/trans seal leaks
Simultaneous motor mount replacement
Broken exh studs?
Rack / pinion leaks from boots / seals
Axle seals behind rear discs / diff seal
Drive shaft out of balance?
Ceramic coat roof & hood ASAP
Replace engine loom wraps if needed
Time windshield replacement w/ upholstery shop to reuphol’r dash if cracked.
BG1988
i just hit 88k i'll do the 100K maintenance thing as well
even though the fluid are new tranny and coolant
mattjones
VA
I recently went from an 08 Tahoe to a 2011 and I’m not sure if they tweaked the maintenance schedule in the manual between those years but I’m pretty sure it had a lot of the maintenance listed at 90k in the 2011’s manual, so you’re at a good place to knock out a lot of that maintenance. Probably want to check out your u-joints, ball joints and other parts that fail eventually.
BG1988
I meant once it hit 100k I just want to keep maintenance good shape..
since I need it to last to 250,000 miles or so then i'll replace it with a '13 hybird
the fluids were all ready changed they're clean. i don't know about the diff though but that will be the 100k service along with the tranny,belt, coolant and oil.. I might not have enough for a HV-battery tell 130k miles
No power steering as it's electric
BUT I will replace the air filter on Sunday I probably have to buy a star key
I gave it to my friend thinking I would never need it again doh not a big deal though...
yes I could use a flat head but don't want to strip the screws
conner04
