Letter from GM on 2017 Denali
Blackcar
Got letter from GM today on my Denaili dealing with increased braking effort ,hard pedal,and or potentially increased stopping distance.Something about engine mounted mechanical vacum pump output. Also says not following recommended oil change intervals could contribute to condition.They extended warranty 6yr or 72,000 miles
Oil change intervals affect breaking? What do they recommend and what are YOUR intervals?
Blackcar
Blackcar
Doesn't recommend oil change intervals just what the owners service interval is which should be what DIC says
the vacuum pumps have been failing that is why they are extending the warranty (it is a known issue), I would imagine this is there way of skirting around a full recall.
I think something happens to a seal and then oil gets inside and that's why it takes increased braking pressure
What years and motors does this affect?
15+, Not sure if they changed anything on the late model trucks, like a different supplier or revision, etc it's been brought up the forum before. I think something happens to a seal and then oil gets inside and that's what causes the need for increased braking pressure
Blueinterceptor
Is there a repair for the problem as in permanent solution or a repair that will one day fail again
KSanborn
I have a ‘16 Suburban that had 47k on it when I had this fail on me driving home last June, 330 miles from home, with my 4 year old in the car. It’s scary because it’s as if you don’t have brakes (makes you feel that way). Took it to Chevy the next morning. The girl told me they didn’t have an appointment for 2-weeks. I told her I’m not moving the car from the service lane. I have a 100k mile warranty. Fix it and I need an equal car due to family size. They finally saw it my way.
dmad1
I received the warning on my '17 Tahoe but it did not extend the warranty
cardude2000
Is the problem intermittent? I got the notice a couple weeks back
petethepug
Michael
SoCal
Our VW had heater recall issues. The heater cores liked to explode. VW played a game stating mine wasn’t covered before it leaked.
Once it did leak I photocopied the letter from another VW owner, brought it to the dealer, presented the letter and explained how my it scared my girlfriend when it let loose and filled the car with steam.
The red carpet rolled out when I mentioned the ice pack on her legs really helped the burns feel better. That didn’t occur, but the dealer got a laugh over it because it allowed them to get 10hrs to pull the dash instead of 1.5.
YukonXLMan
I received my letter and finally took it in after experiencing the issue intermittently. The replaced the pump and hose to the vacuum boost, stating the hose had collapsed. It did make a very noticeable difference in braking pressure, particularly at lower speeds. MUCH less pressure required to affect a stop now and much easier to control the rate of deceleration without major brake pressure.
JeffK
