DIC switch
iLikeEggs
Potato!
Oregon, USA
View media item 27795
This has been done before but it's worth a revisit. As you all know, the PPV/SSV's do not come equipped with the Driver Information Console (DIC switch) at the drivers end of the center vent trim. However, the pig tail connector for the 4 button switch is still there and is tucked behind the panel. This is the set of buttons that let's you toggle through tire pressure, instant fuel economy, chime volume and a few other things. The readout is via the gauges where all there other vehicle info pops up. The switch itself is pretty cheap. You can find it through ebay for about 15 bucks. The option for mounting it is to either get a used center vent trim panel or Dremel out a hole in the end piece. I lucked out and found a broken vent trim section with the DIC switch for about 25 bucks. Problem was that it was wood tone and my SSV trim is flat gray so I will have to fix that later. The end section of the trim that contains the DIC switch is completely separate and only held on to the rest of the trim by two plastic rivets. These can be easily drilled out. Once they are removed, they don't have to be replaced as the ebay rest of the vent trim will fit snugly over it. The end piece has its own clip too so it will fit securely. The whole vent piece doesn't have to be removed to get this done. However, if you remove about half of it and bend the end back to get access to the back of the DIC panel, you could crack the thin section of trim between the AC vents. I so I would suggest removing the entire vent center piece entirely. It is really a pretty simple procedure that will instantly add more features to your PPV/SSV. All I left to do is color match the piece to the rest of the trim. I ordered some vinyl wrap samples off ebay so hopefully one will be a close match. Otherwise I will sand it down and paint.
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
I would use that woodgrain piece as a template and cut out the silver piece so that everything matches, I did mine with a little guess work with a Dremel, tool and it came out fine, I like woodgrain but unless you do everything in woodgrain don't bother putting your DIC into your Hoe. just my two cents.
iLikeEggs
iLikeEggs
Potato!
Oregon, USA
That was my first instinct. Once I see how my vinyl wrap samples look against the rest of it I may go that route. Once I get it all done I will post more pics.
CrashTestDummy
Pearland, Texas
I put my dic in wood also. I didn't mind having my dic in brushed aluminum, but the OEM trim in mine had seen better days.
Be careful around your dic hole with that Dremel....
Yeah, the brushed metal finish isn't that robust, in spite of the fact that all the PPVs come with it. Since our '10 had some rub marks and a couple of holes in that trim, I ordered new from GM. What arrived wasn't in much better shape. I used it because 1. I ordered it new, and 2. it at least didn't have the holes.
After a few years of use, you don't even see the rub marks anymore.
xx_ED_xx
How did you remove your DIC holder? Vents pop out to get to the screws?
RichardCranium
Mebane, North Carolina
The entire horizontal trim comes out with the vents attached. IIRC, start at the passenger side on the end closest to the passenger side door, carefully popping the trim out of its fasteners. Just be careful as it is pretty flimsy.
The trim that holds the DIC is plastic soldered to the bigger part of the trim. You will need to melt the plastic rivets or carefully cut them, to separate the DIC trim.
2011SSVHOE
It's not rocket science guys, Don't ever be afraid to work on your own stuff. worst case scenario is you got to replace the part if you screw it up. Their is nothing better than to have the satisfaction that you can do it yourself. instead of shelling out the bucks to the dealer or repair shop. Remember I always say Righty tighty, lefty loosy.! Have a great day!
iLikeEggs
iLikeEggs
Potato!
Oregon, USA
Uodate: it's still wood tone as I never got around to getting it done. This may indicate what kind of person I am but I'm good with that. It just hasn't been much of a priority. Eventually I will notch it up on the priority list and post the pics. As it is, I haven't had much time lately to post on this forum, which I love.
Lol, cheers.
dizhai
