2007 Yukon Denali Build (This got outta hand really quick...)
Onebad1983
Resident Country Dumbass
We can't get our license in NJ until 17, but we can get our permit at 16 1/2. My first car was an 85 Camaro, 4cyl! Lol, I'd probably be dead if I had a quick car. 2nd car, I was 17 and it was an 85 Z28. That was when I started getting in trouble lol! I did find out that your car isn't faster then the police radio :driver:!
So am I slightly spoiled since I got a big ol' 5.tree for my first car?
Onebad1983
:baby: :doublepuke:
Although, in the past few years the Mustang v6's produce 300 horses.
yeah but one is completely straight piped, no cats, 6 speed. Other than that pretty much bone stock and he thinks he can run with my dad's 550hp magnum
tgui
Same here in my early 20s. ~140mph through new mexico racing a ferrari in the middle of nowhere. Of course a trooper caught us while going the other way. Trooper crossed the median after us, ferrari took off I found a small exit and an underpass, parked my car, opened the hood, got the manual and a can of oil and waited.
Trooper showed up with hand on the gun. Asked what I was doing and I played dumb saying my car was making a funny noise so I pulled over to look at the oil but didnt know how (showing my manual).
I got a lesson on how to check my oil and was left alone. I dont think my butt unpuckered till I hit colorado.
Ahh memories. Huge turbo, all the fixings with methanol injection on top. And I kept it stock looking for the stealth, not that the wing helped though.
My old 04 STi
Fine, one more edit. My 5.0 V8 Lexus ISF current fast car. No one has a clue what it is and leaves me alone.
My apologies to your thread! LOL
Onebad1983
My old 04 STi
PM me more about go fast fun cars. Want to know more about that STI
67RS427
67RS427
I did a lot this week... Started by taking out my BellTech drop struts up front and put in some double adjustable QA1 coil overs and also removed my rear BellTech springs and put in Tony's 5-6" spring with a spacer. I put in helper bags and did the free travel mod while I was back there. Also put double adjustable QA1 shocks in the rear. The truck rides 1000X better now than it did before.
Last week I also redid my air intake and used 5" tube for the entire thing. Added a honeycomb before the MAF sensor as well...
67RS427
67RS427
If that wasn't enough, I also installed a Mishimoto Radiator (for those wondering it performs way better than the stock one). I got some great pricing by calling direct. I also installed 7 & 9 blade fans from a 2500HD truck.
In addition to all that, I upgraded to a Granatelli 103mm Throttle Body... Too many issues with my Nick Willams and the throttle blade snapping shut from the blower
Front suspension:
67RS427
67RS427
The list goes on... I also upgraded my fuel system to -8AN line and added a second Walbro 450 pump in tank that is on a 7PSI Hobbs switch so I can start to run E85. Also added a chiller for the blower. It was a pain in the ass to plumb everything, it's literally 50LBS of crap in a 5LB bucket. Sorry for the lack of pictures, it was a super busy week and I forgot to take pictures along the way.
992dr
Eastern N.C.
Nice upgrades. Lookin good.
Do you have a part number for the rear shocks? I wouldn't mind upgrading from my Bell Tech shocks. I have Tony's 6" coils but am using heater hose instead of the spacer for a little extra drop.
Are you using those heat exchangers in your system? If so, where are they located and what are they plumbed to?
I was considering converting to AN lines. Did you change all fuel lines front to back?
I saw a pretty nice 20 AN bolt on thermostat housing but, I'm trying to figure how I'd plumb it into the radiator.
67RS427
67RS427
Those Bell Tech shocks are crap and were fully extended with my small drop. The new lower shock mounts Tony gave me were even lower than the ones I had in there so they just wouldn't work.
The shock I'm running is a QA1 Stocker Star TD905... They fit perfectly for width of the mount as well as bolt diameter with the bushings that come with them. I'd double check your measurements eye to eye at ride height but they have a ton more travel over the Bell Tech shocks. They are a little over 23.6" extended and 15" collapsed.
The heat exchanger I posted is a plate type heat exchanger/condenser that I'm using to chill the fluid going to the blower brick. It's tied into my AC system and gets the supercharger fluid down to 30-40 degrees allowing my intake Temps to be well below ambient temp even in 100+ degree weather.
I already had -6AN fuel line front to back but with E85 I needed to upgrade to -8AN for feed and return.
992dr
Eastern N.C.
I'm wondering if I'm having the same issues with my rear end. Either I'm bottoming out or the bottoming out the shock. Either way, it sucks.
I'm going under tomorrow to check a few things, I'll try to get a measurement. Do you remember what yours was?
Yes, I am familiar with that style heat exchanger and have many different sizes of them at my disposal. What a clever idea, nice. How'd you go about tapping them? In a mill?
Gotcha, is that something you did earlier on?
Love your build, such a bad ass SUV.
randeez
south florida
time to get those times to match that mph :chewie:
the few times ive had mine at the track ive stiffened the hell out of the front and softened up the back to let it plant better. I have a lot of weight over the front now helping keep the front down and from spinning so much - that is with moving the battery to driver side tray above windshield fluid, 50lb turbo hangs in front of the wheels, 4" intercooler.
67RS427
67RS427
My goal before summer is over is to run a 10.9 qtr... I don't think it'll be a problem on E85 if I can get this thing to hook. If I can't get faster than an 11.5 or so I'll switch out these 90LB 22" wheels/tires for a lightweight set of 18" wheels with drag radials. It would save me 30-40 lbs of rotating mass at each corner, that should certainly be enough.
randeez
south florida
no doubt a tire would help, but its even sweeter being able to do it on the wheels you want to run - thats what the suspension will allow for... jump to a drag radial when you trying to meet your next goal, keep them in your back pocket in the mean time :cheers:.
that mishimoto radiator does look nice, i was looking at my poor little 2 core radiator the other day, havent really seen the need for an upgrade so far but i'll definitely be looking into it when times comes.
hoping to get mine back together before winter, our "race season" down here... rest of the year its too hot and humid to hope for good times. e85 is a lot more forgiving with the high intake temps and i usually try and run it year round
esoteric_ast
Question about your Walbro 450 install. How difficult was it to swap the pump? Any mods necessary? Most info out there is for the pickup trucks that have a different tank, etc.
67RS427
67RS427
Sorry, I've been terrible about updating this thread... I just looked and it doesn't seem like I took any pictures during this last fuel upgrade. There really isn't much to upgrading the pump. Use the factory bucket and gut the thing, saw off or grind down anything on the inside of the bucket to make as much room for the pumps and fuel volume possible. Drill a hold in the top of the bucket with a step drill for an AN bulkhead, use a 90 degree fitting (or two) off the top and a Y fitting if using dual pumps. Wiring is plug and play with a Racetronix hot wire kit (you can also make your own). They make a kit for single and dual pumps that works great. Run -8AN if you plan to use E85 or are making big power. It's a pretty simple install, if your truck is newer you might have a FPCM that controls the OEM pump voltage, you might need to reprogram it if you plan to keep it.
**I forgot to add that with dual pumps, you should drill some 1/4" holes about halfway up on the front of the bucket to avoid sucking the bucket dry when under 1/2 tank of gas. Also, dump the return using the factory supply directly into the bucket. Make sure you use submersible fuel rated hose in the tank and just zip tie the pumps together. With two pumps and the socks on the bottom, there is really no movement or anywhere for the pumps to go.
JamesinAbilene
