dszx13
Put a cammed 6.0 in they said....
Keviebear86
Sorry but no pics. I recently did a whole lot of maintenance work to my truck to ensure that it'll run while my girlfriend drives it.
Front/Rear Powerstop Pads/Coated Rotors
AC Delco Spark Plugs/Wires
AC Delco U-Joints
New tailgate/window struts
oil change
Rear Hatch Glass (heater element connector broke off)
EVAP purge valve
And coming soon I'm going to do a transmission service as well as both differentials and I have my tires here at the shop to replace the worn out tires. I currently have a LT285/60R20 Firestone Transforce AT, which equals out to something like 34.5" tall tire. I'm only lifted 3" so I'm going down to a P275/60R20 Bridgestone Dueler AT Revo 3. I work at a Firestone affiliate so we get a really good discount for the tires and they are on a rebate right now. Can't pass up a chance to save a few dollars!
dszx13
Anyone use amsoil? Just ordered oil for my Yukon and wife’s impala.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
so sat. i was adjusting the outer handle rod to lock on all for doors. checked the doors before reinstalling the panels, doors open and close. so i put my tools away and lock the doors, then i return back to the truck unlock the doors with the fob, i hear the locks move try to open a door nothing so i try another door nothing, so i try another door and still nothing. i'm like wtf is going on here, so i try one more door and it opens. so i might have over adjusted the rod, now the funny thing is i couldn't open the doors from the inside as well. so i had to pull door panels from the inside of the cab while the doors were closed, let my tell you it was not fun hands are cut up and scrapped up.
DougAMiller
Colorado
Did the Bose PREM to LUX upgrade over the weekend. The LUX amp certainly has more output. I had picked up a LUX Nav radio and LUX amp pretty cheap on ebay, so thought I would try it out. The amp is definitely worth keeping, but since I built a nice nav system into the map pocket area of the console using an 8" Android tablet, I don't really need the nav radio. I may reprogram my UC6 radio to Y91 configuration and put it back in, since I think I like the looks of it better.
Did you post a pic of your setup?
HiHoeSilver
Away!
Chicago
Are there RPO codes to tell if you have premium or lux?
Korbin_A
