Another light bulb thread BUT not a fitting thread!
Rosson03
Kentucky
I purchase JDM led headlight and installed them with no problem no cutting, no modification I also got fogs, (should of got the headlight 1s)has any1 tried those) turn signals, and side markers
B4
After
Yes every1 will hate me but my front windshield is nano tinted.
Rosson03
Rosson03
Kentucky
Fogs could be better
Has any1 have the other 1s that look like headlights for fogs
Just fogs, needs to be better
Rosson03
Rosson03
Kentucky
These r the fog headlights I'm talking about. Any1 know these fit and work
I've got JDM Astar LEDs all around, inside and out, and I am very happy with them. Equally important, I'm very happy with the folks at JDM Astar, who assisted me in getting the right LEDs to replace all of the incandescent bulbs. We had a couple of trial and error situations, and they worked with me, taking back any LEDs that did not fit perfectly, until we successfully completed the entire conversion.
The specific LEDs that I used on my 07 Yukon XL Denali are outlined in this thread, Post #8. https://www.tahoeyukonforum.com/threads/time-for-new-headlight-assembly.108917/#post-1300357
Rosson03
Rosson03
Kentucky
Good job, just read it, just my front and top tail lights jdms my reverse are vleds I will eventually get the turn signal and the tail light JDM s but trying to figure out where to put the resistor is a challenge where did you put yours
Rosson03
Rosson03
Kentucky
Oh by the way where did you put your resistor for your turn signal
And did you use the I don't want to say cheaper is not the right word less of a price 5202 is for your fog lights compared to the 69 or 49 or 99 dollar bolts
Rosson03
Rosson03
Kentucky
I'll make it easy on you what bulbs did you use for the 5202
My bad on the price of the fog lights in my thread, as my actual cost at the time was $60 (I just corrected that thread). It looks like the price of this specific fog light is now $69.
From that corrected thread for the fog lights: For the fog lights, which were the 5202 incandescent spec, I used the following: JDM Astar LED Number 2G 5202 5201 Fog Light CSP (white is the only available color) ($60 per set of 2) (Note that I had to slightly cut down a protrusion on the plastic bumper housing behind the fog light lens assembly with a hacksaw blade to fit the LED into place, but the modification is completely invisible and took about 2 minutes each to accomplish.)
Regarding the hyperflash from using LEDs, I did not use any resistors, and simply kept the hyperflash. There was no simple place to mount the resistors, where they would contact only metal and not plastic, and I did not want a hot resistor contacting any plastic on the truck.
I understand that hyperflash may be illegal in some states, but it is not in mine. And, no harm will come to the LEDs or the truck from hyperflash. Last, I believe that other drivers will see a hyperflash directional signal more readily, than a regular cadence flash directional signal (just my opinion).
BTW, the front directional signal JDM Astar LED that I used is a switchback LED, and the white running light, when not using the directional signal (yellow light), is very bright, and further improves forward visibility.
I trust that this is helpful to you.
Rosson03
Rosson03
Kentucky
So do they go far out like normal headlights, cuz I bought the less expensive 1s, they r actually fog lights they only go so far like 10 or less infront of truck
Thank u every1 for ur feed back
Yes, the LED fog lights to project out in front of the truck for a short distance, but being fog lights, their primary purpose is to provide good illumination and visibility in the short distance in front of the truck.
Rosson03
Rosson03
Kentucky
Thank you you answered what I wanted to know so It kind of don't matter what bulb 2 get they show same length. Just some more brightness than others
I was kind of hoping for extra set of driving lights
For extra distance to supplement headlights, some folks have installed LED light bars of various sizes on the front of their trucks. I'm not sure about the legality of running those LED light bars, in addition to the headlights, in populated areas. However, generally when you want extra forward illumination, you are not driving in populated areas, where lots of background light already exists.
As I previously indicated, the switchback LEDs that I am using on the front for both directional lights and running lights, actually supplement the headlights very nicely for front distance illumination.
