Rear main seal replaced now ticking noise?
JML07denali
So last week I had the rear main seal replaced. I get the car back and I hear a faint ticking noise I don’t know if it is a lifter or a exhaust manifold leak? Does anyone know if the exhaust manifold would have to be removed or loosened to replace the rear main seal?
The noise is coming from the right hand side of the engine. It seems strange that’s I have this issue right after this repair. Any suggestions or advice is appreciated.
Thanks
Both sides of the exhaust need to be removed but not the manifolds, just from the manifolds back I believe. At least on my 02, not sure about the NNBS. Might be leaking from where the manifold bolts to the mid pipe. But yes Id say most likely an exhaust leak.
JML07denali
JML07denali
Looks like it’s going back to the shop so they can fix it! Keep the thread updated on the outcome.
JML07denali
JML07denali
Anyone know of a clamp kit to fix this?
Search for Dorman GM exhaust manifold clamp. Make sure to get one for the correct position, there’s 2 or 3 different ones. Looks like passenger side front?
JML07denali
JML07denali
Yep!
KATfishing
I believe Kral Auto Parts now has a clamp for every position. I have a 6.2 and have clamps on rear bolt positions, both sides. They've been on for 3 years and zero issues. Still runs quiet.
davekalk
