2018 Denali Lane Departure Warning and Front Parking Assist
wa3cuj
My vehicle is 13 months old and I just turned over 10k miles. About a week ago I developed a change in my Lane Departure Warning and my Front Parking Assist. I use to get a vibrating seat as soon as the icon for either of these changed in the drivers display. Now the icons change but no vibration or beep (selectble in vehicle settings in the Infotainment Center.) I do get a vibration when the rear sensors detect something.
I had the vehicle at the dealer today and they contacted GMC. The answer they gave me is that the vehicle is behaving as designed!! I can't believe this, since for 13 months it would vibrate immediately when the lane departure icon changed from green to amber.
Having and icon change color is not much of a warning! A vibration or beep is needed and it use to be there.
How is the system working in your vehicle??
Boatguy
So Cal
2017 Denali here with 8,000 miles. The Lane departure feature is all but useless. It buzzes my seat about one time in ten when testing the feature. The Lane keep assist isn’t much better. It will pretty much bounce us off the guardrails if it steers at all.
My biggest peeve though is the adaptive cruise control. It follows too closely. All these issues have been brought to the dealer’s attention (twice), and both times the car was declared “within spec”. I showed the service manager a video of our Denali tailgating a truck on the freeway, and the response was “if the vehicle isn’t throwing a code, I can’t replace anything.”
Now the front parking feature works great. I park in the garage, and I get buzzed every time going in.
I’ve posted my problems with the lane keep assist and ACC before. Others have responded theirs works fine. I guess there is kind of a lottery with these cars. Some work better than others while all are “within spec”. I wish Honda made a full sized SUV.
Edit:I don’t dislike this car. This is the most comfortable road trip and trailering vehicle I’ve ever owned. I just wish more of the tech worked like our 2018 Honda’s does.
Michigan, Metro Detroit
did you tried adjusting the gap ? what i mean ...there is a menu where you can choose how big of a gap you want to leave between your vehicle and the vehicle ahead. supposed to be 3 settings on how far you want to be away from the car ahead.
Boatguy
So Cal
Yup. I’m on the longest gap. Reducing the gap only makes it follow closer, but not by much.
I’m not unfamiliar with the technology. This is our second car with these features. I liked them so much on our Honda, I shelled out the extra bucks for them on the Yukon. Such a disappointment.
We’ve done another road trip since my first post above. We just use the ACC as a regular CC with the + and - buttons. This actually saves the trans from another deficiency: when there is a big gap (>10 mph) between the set speed and the actual speed, when the car you are following gets out of the way (as it is likely to do because we are tailgating them) the computer seemingly floors the throttle. The trans drops two or three gears and all 420 hp are called upon to resume speed. This cannot be good for trans longevity.
Still, this is our most comfortable road trip car ever. We put the AWD and 4WD to the test pretty ******* the last trip and they performed great.
hmm... if everything working as it should the algorithm shouldn't allow it for hard acceleration like that. I worked on the 77 ghz and the 24 ghz radars for BSD and ACC in my past days when I was at Continental. When you follow a car on a curve do you see anything changing ? I would ask the dealership to run a calibration on it.
Boatguy
So Cal
The only thing that happens on curves is you must disconnect the ACC or it can lock on the vehicle on the outside of the curve in the next lane. If that vehicle is going slower, the ACC will command brakes. But that is in the manual, so I just don’t use the ACC on a curvy freeway.
Interesting you say the throttle should not go WOT when the ACC resumes. Maybe I have another reason to try another dealership.
You mentioned “run a calibration on it”. The service manager told me there is nothing to check on these. They are either throwing a code or they are not. According to him.
pwtr02ss
Tennessee
My 19 has had the light on the mirror come on at random times since it was new (3k miles now). Its had "front sensor blocked, refer to owners manual. Forward collision disabled" come on twice. The first time it was pouring rain so I assumed that was the issue. The second time it was clear and nothing around me. Last week my wife was driving and it popped up "take control of the wheel". I'm not sure if these issues are common or not. I haven't had time to take it in to the dealer.
PG01
Up here to the right
My 19 den xl has 2000 miles on it, I turn all that crap off. Ive used the cruise when i drove it home from dealer and it worked fine.... wife says she uses it around town (not sure why but hey, whatever she wants) and it works fine.
PG01
I got that driving home from dealer, i was seeing how much it would float in the lane, it went side to side then beeped and vibrated and said take control....
pwtr02ss
Tennessee
She was just driving up the two lane road. She said she wasn't on the line but who knows. The seat should've vibrated if she was getting close, I would think
Bob2C
Northern VA
If equipped, LKA may help avoid crashes due to unintentional lane departures. It may assist by gently turning the steering wheel if the vehicle approaches a detected lane marking without using a turn signal in that direction. It may also provide a Lane Departure Warning (LDW) alert as the lane marking is crossed. The system will not assist or alert if it detects that you are actively steering. Override LKA by turning the steering wheel. LKA uses a camera to detect lane markings between 60 km/h (37 mph) and 180 km/h (112 mph).
applegate123
I just purchased a Tahoe Premier with 12K miles. Trying to troubleshoot the same issue as the OP. Since this is my first use of the vehicle, I don't know if this is a model year feature change. Seat buzzes when getting close to objects when parking, but does not buzz during lane departures. I just traded a 2015 Tahoe and it did buzz the left or right of seat depending on the line that it was crossing.
applegate123
The windshield was replaced on my truck prior to my purchase - I was questioning if this had anything to do with my issue. I assume that you did not have a windshield replaced? I have not been to dealer yet - if I get the same answer, I will want to test drive a new vehicle to determine if it behaves the same. But as you indicated, it was working "correctly" during the first year of ownership..... the only way to test it is let go of the steering wheel???????
Bob2C
Northern VA
I was on the highway this morning and I did drift over the line. The seat did vibrate on the left side which was the side I drifted. This wasn’t intentional. I was about half over the line. It got my attention. So I tried to replicate again and I could not. I think a lot has to do with if the vehicle is getting any input like acceleration, steering etc. My take, it’s there when you need it.
08HoeCD
LOL
I'd do all that I could to turn these annoying features OFF.
cardude2000
LOL
You can’t turn ACC off.
Well, I guess you could disconnect the camera or module and the acc literally wouldn’t work.
But you’d have to put up with a constant error message.
on some models you can, it has been noted on the forum before and confirmed on the GM owners center website
6point2lovelifers
