Thinking about swapping my 06 Denali xL from column to console shift
Worth the extra effort to convert column shift to floor shifter?
  • Total voters
    17
Bdubb
Chicago
So i got the idea to convert my Denali from column shift to floor/console shifter. After looking at a column from a 4.3 Stick shift Silverado, it looks like the columns are interchangeable. the wiring inside would need to be switched over but that's about it. The manual trans trucks weren't available with steering wheel controls. I also looked at the floor shifter from a Trailblazer SS. Doesn't look like to much work to mount it in the Denali. Just needs a mount made to bring it up a few inches higher than it is in the SS. The SS shifter cable also looks like it will be long enough to work. The overdrive button on the shifter handle can even be wired as the tow/haul bottom that's normally found on the column shift lever.
I think it would be a cool idea. Looking forward to seeing the progress
X2. Sounds like a great idea. I'd love to see how it turns out.
Grabbed this screenshot off the forums. This is the trans tunnel on the nbs Tahoe. Looks like it was meant to be there.
SSE1
I've always wished that GM would've located the shifter in the console , I'm anxious to see how it turns out for you
01DenaliHiker
Florida
I literally spent an entire night googling because of your post. I'd be interested in seeing the SS shifter in your body style, but the best look I've seen with about eight hours of googling is a Silverado/Sierra rear entertainment console with a B&M megashifter 80680 protruding through the slot left of the cup holders with a modified boot. Removing the column shifter and splicing your wires together keep your P alert and indicator functional even with the floor shifter. Seemed like a easy enough job with patience to get the test fit right before snugging everything. Plus, slap shifters just make you happy.
...... You've inspired me to spend even more money now. :yuno:
That looks sweet!
adriver
Never!!!!
That's not my fault most people would rather be lazy and let the transmission decide on which gear they should be in. I like to have as much control over my 3 ton bullet as I can.
Sure looks like the floor pan is separate, and probably easier to keep the same stamp for all of them, then to make a new one just to not have the area separated for the manual trans...
Also, I thought they did come in manual around the world. Wasn't a manual an option in South America or Mexico? Probably Africa too if they ever did it. The Silverado/sierra weren't assembled at the same places as the Tahoe/Yukon (AFAIK), but that doesn't mean the pans weren't stamped at the same place. Someone else might know easily, but I have no clue on the process, (just throwing stuff out there).
01DenaliHiker
Florida
I'm messing with you, I myself love being in control of my transmission. Drove standards my whole life, and continuing if I have to drive the tractor trailer at work with the heavy dozer. Best anti-theft device on Earth. Lol. But I would not enjoy my Denali as much if it were a manual, it's nice to let something else do the work for me for a change; Besides, I tell mine what I want through tunes almost weekly if I'm not happy.
:Angry:
Bdubb
Bdubb
Chicago
Picked up a tilt column from a manual truck. Harder to find one with tilt than I expected. Gonna take the next few days to strip it down to switch the wiring from the denali into it. Also, the gear selector indicator gets its signal from the black box on the side of the trans, not the actual shifter on the column like the older trucks. No splicing or rewiring required.
drowssap
Colorado
I posted this awhile back but I see some new people in this thread. I m trying to figure out the best manual trans for my 8.1 Suburban.
01DenaliHiker
Florida
Yes, but the two wires that connect on your shifter in the column are what supplies your P shift indicator. It'll still function, but will not give you the indicator box. Thus you won't know when you're in park. Black box gives signal on the trans for selection, those two wires somehow link everything together. Seems to have been a headache for the silverado world all the way up to 2006 for those that did it.
Try it without them connected first, but leave it as an option just in case your indicator isn't showing up. If not, just splice them.
Bdubb
Bdubb
Chicago
The two wires on the column shifter are for the tow/haul button. The trailblazer ss floor shifter has an o/d or traction control button on the shifter handle that can be wired as a replacement for the tow/haul button.
Bdubb
Bdubb
Chicago
Also, the trailblazer ss has the gear indicator in the cluster as well. It shouldn't be very different in wiring . That would make it more expensive for GM to come up with two different methods of getting the same info to essentially the same place on the cluster.
adriver
The 8.1 (and the 6.6 Diesel) came with the zf-6 behind it in the 3500.
inmypassatlife
@JKmotorsports already did this, theres also a link of a fella who went to manual trans and used a tierod end as the pivot point. looks good. If you're going to floor shifter, might as well go manual
briannorris
