992dr
Any updates?
How's it been runnin?
Any updates?
In it for the donutsIt's been running pretty damn good... Much better since my track day in October now that I have the transmission issues worked out. I'm in Michigan so it's been boost weather for sure, cold and dense air. I've been tweaking my tune and had some issues with my Nick Williams 102mm throttle body putting me in limp mode randomly under light load and let off of the throttle (TB motor getting weak, that's what I get for being cheap and buying a used TB). I ended up pulling the 102mm off and putting on a LS3 throttle body the other day. I'm probably down some horsepower (25hp) at the wheels overall but the response is much better with the smaller TB. I might end up keeping the LS3 TB and just porting it. Those larger 102mm and bigger throttles act like an on/off switch for the engine lol. Much smoother with the 90mm LS3 on there now. Once I get it how I want I plan to get it on an AWD chassis dyno. A friend has one locally but these trucks only barely fit with about 1 inch of space front and rear on the roller. It can be dangerous if not strapped properly but I really wanna see what this thing is putting to the ground. I'm certain it will hit 700whp though... I will post some updates soon and if we get some damn snow, I'll certainly post up some donut videos.
Lol
That's awesome, glad to hear how well its running.
Could you refresh my memory, What was up with the trans?
How's the tuning part coming along? I'm really interested but, definitely intimidated with any tuning. My local (who's really not local after we moved, haha) guy is about 3 hours away and there is one guy in the town we moved into but I really want to learn on my own and not have to rely on anyone.
Is it something in particular with the NW TBs that this happens? I think I've seen that before.
I'm definitely in for how much power its making.
What's your motor set up? Forged internals?
AWD donuts would be sweet haha. Lookin forward to the vids of them.
Sorry, almost forgot. I think I posted the build but can't remember lol... It's a 6.0L LQ9 iron block .005" over and a Lunati 4" stroke (402"), Lunati Rods and Weisco forged pistons. Billet double roller timing chain, ATI 10% over damper and Weapon X 2.5" upper. Makes 14psi all day, 15-15.5psi peak. Self ported blower and Stage 3 Brian Tooley Racing Positive Displacement CAM Motion CAM. I used my L92 heads from original motor and rebuilt them with a BTR Spring kit with titanium retainers and upgraded to lighter Manley valves. So much more I'm probably forgetting. Any questions feel free to ask away... I got lazy updating here and have done a lot over and over lolThat's awesome, glad to hear how well its running.
Thank you... Kind of a trickle affect as you know but as I mentioned in your thread, I can't buy a new or used car/truck that even comes close to what I've created for less than $50k. I also like that it's "#builtnotbought" by ME!That is quite of transformation, Nice job Matt.
So this is where things started going sideways... I was finished porting the blower, pressed on new Weapon X hub and 2.5" pulley, completely rebuilt blower with new bearings and fresh oil, reinforced the intercooler brick, assembled the entire motor and reinstalled the entire powertrain (Front diff was out and rebuilt, Transmission was out and rebuilt again due to a bad 3-5-R clutch pack, Transmission reinstalled with the new Circle D triple disc torque convertor, TCI Flex plate and new custom driveshafts installed with the original transfer case)... All that work didn't take too long believe it or not. My issue was with my new 8 Rib LSSimple accessory drive kit. It should have been a direct bolt on and I was truly impressed with he way it LOOKED. It should have bolted on in 15 minutes but it's function however was terrible. I can't recommend anyone uses the LSSimple kits. They had a bad batch of laser cut plates in my case and shipped me a system that they knew was bad but tried to salvage. He elongated holes and used washers/spacers instead of solid mounts. It was terrible and out of alignment from every aspect. It wouldn't track a belt properly even during cranking. I wasted over 6 days trying to make this kit work. I had access to a Bridgeport and a lathe and still couldn't get belts to track properly even after machining new spacers and tweaking things. Murphy @ LSSimple was very apologetic and refunding my money without even asking for the kit back (which is garbage!). That 6 days cost me weeks in the long run.
Looks pretty but doesn't fit or work for shit... Bracket was contacting bottom of snout, had to take out 1/4" of material on the bracket just to start test fitting this turd:
Idlers not lining up at all, the alternator and tension on the opposite side were also canted back in different directions... Still couldn't get it right even after taking the spacers down in the lathe.
Luckily I found a guy locally in Michigan that is very big in the LS Swap stuff... Here is a pic of one of his garages, lets just say he has a few blowers laying around if anyone needs parts ;-)
He hooked me up with a Holley alternator/power steering mount kit and I used an LSA Water pump and factory LSA accessory drive parts for everything else. Came out a hell of a lot nicer in the end and I know I'm running something factory proven and the blower is on it's own 8 Rib belt. Only thing left to do is relocate my factory A/C compressor backwards 1.5" on the LSA A/C bracket so I don't have to cobble together custom LSA to truck A/C lines and electrical. Pics of that to come in the next few days.
Thank you, it's been a roller coaster but well worth the hard work... I've been slacking on the updates and content but I'll try to get some updates and new content posted soon.Wow! Awesome truck. Awesome thread. So jealous of that beast, and your skills and knowledge. Keep those posts coming!
Lol, nah... Not even really about the motivation. I honestly see NO scenario where I would want the ABS and/or Traction/Stabilitrack ON. I had so many issues with my old TB SS and Silverado SS with pulling out into traffic and it going on and I just thought it was dangerous when the power would cut out and leave you with no power. My foot is better at controlling the traction than the stupid GM Stabilitrack. I'd rather have complete control over what the truck is doing, I don't need the electronics. I've never needed the ABS either, it stops just fine in snow and ice, you just need a good tire.and no motivation to add one switch? lol
Pretty sure the only one I removed was the 40amp. I know for sure that one is pulled, I don't recall pulling #9. I'm in Florida till Tomorrow, I'll check when I'm home.Did you remove #61 ABS 1 (40A) or #9 ABS 2 (25A)? I have been removing #9 only
