HOW TO: Convert to Escalade LED Tail Lights
THE YETI
THE YETI
Director of Operations
South FL
VLEDs doesn't sell the 6ohm/50w resistors anymore. You can google search and find the right ones.
You can put anything between them. Aluminum plate stock from Home Depot, for example.
I usually just space them out away from the Hopkins with zip ties.
08burban
Okay I will give it a shot and try to make this harness myself. I appreciate all the info you have given me thank you.
mike11747
do you have an email where i reach you i would like tho get this done if your still doing it
MudnRox
Rebel without a clue
Olathe, Ks
I will be in touch with you as soon as I can score some Esky taillights. Lovin the way those look
Gimmer
Hello. I have a '13 Tahoe and would like to replace the rear tail lights with the original Escalade LED tail lights. Came across your post, nice job by the way, and am wondering if you would be build a direct plug and play harness? I will provide both harnesses and pay for any additional expenses. Thank you.
THE YETI
THE YETI
South FL
Thanks for the compliments. Unfortunately I don't build these anymore. Too time consuming and frankly just not enough time.
timotheus1234567
PARTS LIST PRICES AND HYPERLINKS FOR PURCHASING:
Hopkins Harnesses (you need 2) at $9.42+shipping
http://www.amazon.com/Hopkins-48845..._1?ie=UTF8&s=automotive&qid=1306088173&sr=8-1
6ohm/50 watt Load Resistors (you need TWO of these at $6.99/pair, so 4 individual resistors. Total is $13.98+ship
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/6-OHM-50W-2-BULB-LED-p4783296-1-2.html
Mounting Plates (you dont NEED these, but I wouldn't do the install without them) $5.99/pr, only need one pair.
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/2-LOAD-RESISTOR-MOUNTING-p6841378-1-2.html
Tahoe Tail Lamp Harness (you don't NEED these unless you want to keep your stock harness) Roughly $40/ea (EBAY seller has them at $10+6 shipping per harness)
http://cgi.ebay.com/ebaymotors/07-T...294756QQ_trksidZp3286Q2em7QQitemZ260785044829
---------- Post added at 01:38 PM ---------- Previous post was at 01:21 PM ----------
PM for pricing :Handshake:
Thanks guys! Took awhile to get the harness down pat! Just glad I kept it clean and factory looking with the harness. Takes 5 minutes to swap back to the stock tail lamps if need be. :)
I have a question. What if I wanted to do the opposite. What if I wanted to put a Yukon harness on a escalade.. This is what I want to do.. In order to install Yukon after market lights on the escalade
Diesel07
Would you be interested in selling/swapping tail lights? I have a 2016 Denali.
Thanks
Justin
pako
I’m interested in your wiring harness I’m trying to swap rear tail lights from a 2007 Escalade to a 2007 avalanche pleas send me your number or email we’re i can contact you
pako
I’m tryouts no to swap 2007 Escalade rear lights to a 2007 avalanche I’m interested in the wire harness you sale can you pleas send me your info
LanceD
AZ
Since the OP isn't making or selling these any more I thought I'd throw up another option.
This only works if you have the trailer harness up by the spare tire or plugged into the back of the 7 way plug:
Buy this: CURT 56584 Custom Wiring Harness https://www.amazon.com/dp/B007EA6WQU/ref=cm_sw_r_cp_apa_i_JHO5AbWPJPPR0
Clip off the 5 pin plug and add two of these with associated pins and seals with some wire. You get a ground, reverse, brake/turn L/R and park.
https://m.delcity.net/store/GT-150--Male-Housing/p_810485.h_810490
Plug it in and go. Should cost less than $50 for everything brand new.
Only thing you would need to do is add a resistor to keep the blinkers from hyperflash.
I can assemble this for you if you don't like wiring stuff for a fee. Just thought I'd try to help whoever is still looking to do the mod.
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
Just did the swap tonight, the write up helped a lot thanks!
BG1988
the swap is pointless just get some Taheo hybrid led lights
Capybarbro
