Adjusting Headlights
Chevyrider619
Virginia Beach
Ok new headlights are on now..So now my question is,does anyone know how to adjust them?? I was looking at the manual but they say to take it to the shop,forget all that..Any help would be appreciated:hmm::think::think:
riviera rider
i havent messed with mine yet but there should be some sort of screw that either moves in or out to position the headlight angle up or down you mite have to mess with it a bit to get it where you like it, but ill look at mine tomorrow and let you know for sure
haks310
Got LEDs?
SoCal
Each headlight has two screws, either a Phillips head or a T15 hex, IIRC. One for up and down, other for side to side. They are hard to miss.
"350Vortec"
*Tahoeless, For now*
Careful, On older trucks these adjusters tend to break VERY easily.
DJTricky
Banned
Robbinsdale MN
hahaha here you go man, right out of the GM mechanics book if you dont have the headlight aimers
1 - park your truck 25 feet back from a wall ( has to be exactly 90 degrees)
2 - measure from the center of the headlight (the little O in the center of the low beam lense)
3 - take that measurement to the wall and mark 4 inches lower then the hight of the headlight.
4 - measure from the center of your truck to the same O on the lense and transfer that line on to the wall also.
5 - adjust the hot spot of the light to the cross section and your done
ravingmadman
Chief Knuckle Buster
Greater Seattle
I broke the crap out of mine, and they're new. The adjustment screws are accessed from the top. There's a hole in the top of the grill where you can get a phillip's or torx wrench down into. The bolt turns a worm gear that pushes the bottom of the light in or out, and that's what breaks. It's a little 4-pronged plastic failure of engineering on GM's part. Oh well.
riviera rider
im going to have to be carefull messing with my new headlight setup then
Chevyrider619
Chevyrider619
Virginia Beach
I was checking the screws on the headlights,i'll do them tonight...They have adjustment but for a stock tahoe not lifted so i have my headlights pointing down to low..
preshus
washington,IN
which screw is for up down and left to right
---------- Post added at 02:29 PM ---------- Previous post was at 02:28 PM ----------
google won't tell me that one
NOVAhoe
Manassas, VA
the one for up and down is the inner most screw, closest to the hood latch, the one next to the fender is for left and right....obviously haha
TahoeLimited
Fountain, CO
Newbie Needs Help!
I've read this thread from a couple years ago, and am concerned that I'll break the adjusting T15 hex screws. I tried turning them a little yesterday, and they seem to turn, but the headlamp didn't move. I'm also confused as to what the male (protruding up) adjusting "rods" (with a hexagonal nut-style tip) do. I turned them quite a bit and nothing happened there either.
As you can see from the pics, I'm interested in adjusting the inside driver headlamp down, so that it fits squarely in the grill frame.
Any specific instructions would be greatly appreciated. I just bought this limited earlier this week and I'm diggin' it. The body is extremely straight, and aside from paint blemishes, this misaligned headlamp is the only thing not straight on the exterior!
I've included a couple pics of the holes...if anyone can give me specific instructions, referring to them, that'd be great.
TIA,
Terry
SunlitComet
OBS Jedi-Do Good
unknown at this time.
The hex heads sticking out are basically a screw in rod that hold the lens section to the base section you can unscrew them so far and pull out the rest of the way to pull the lenses out and get access to the bulbs and connectors for changing them out. The other two deep in the holes are for vertical and horizontal alignment.
99TahoeTow4WD
And now the answer you've really wanted to know: on my after market headlight housing, for up / down, turning adj screw clockwise moves the beam down and counter clockwise moves the beam up.
Read ad nauseam for technique. Mine only needed slight adjustment, so no measuring tapes. I just pointed vehicle at brick wall for calibration.
Didn't adjust left / right though, so you on your own for that.
ColdIronAxe
Awesome, I love it when someone writes a detailed and precise response my man!
dizhai
