For those running cut 6” Norcal coils for 7” drop
Blittlejohn53
I’m running Tony’s 5/6 drop with helper bags and 22 reps.
I want 7 drop to match the front, going to cut half a coil out, seen a few guys on here saying there running that set up just looking for some feedback on the setup.
JasonLmarsh
Just curious here, How would you cut the spring and have it fit properly in the truck? The upper and lower ends of the springs are tapered down to fit the spring pocket. If you cut the spring how will it stay in place once the inner dimensions of the coil spring is 3"-4" larger than the spring perch?
Doug118
Also curious as to how you'd go about that
1lowhoe04
Fort Worth Texas
The upper spring is a pocket / cup it sits into tony says you can cut his springs and the weight of the truck will allways keep them in unless you put on a lift and drop the rest end !
I have his rear springs in mine have not cut yet been debating on doing so
Did u ever cut them and how was the ride ?
Drewphil
