Bilstein 5100 and leveling kit advice -updated. Job done
Mighty Hd
Florida
13 tahoe z71. Running duratrac 285 65 18 on factory z71wheels.
Zone 2” leveling kit. It goes under the shock absorber. Rear is at stock heght.
No rubbing in the front and only rubs in the rear at sharp angles
Two questions:
1. What position do i set thr front bilsteins to if i keep the shock spacer leveling kit? I am assuming the 0 / factory ride height as the spacers will do the levelng
2. With the bilsteins, is it advised to switch to a top mounted strut spacer or can i simply continue to run the lower shock spacer?
Thanks
M
Mighty Hd
Florida
I got them installed yesterday. Ended up keeping them at factory height and using my existing zone off road 2” leveling block under the shocks in place.
The ride is a 100% improvement over stock. Combined with thr new duratrac d rated tires I’m very pleased.
For the record I went through two sets of BFG AT KO in 50k. The first set has 3/32 at 27000 miles and the second set (KO2) was at 4/32 at 23000. Rotations every 4000 miles and alignments every 10k. Discount tire warranties both sets..the second they were more reluctant but I had a mountain of paperwork for alignments and rotations. A total shit tire that looked great but damn near suicide in the rain.
Quite impressed with thr duratrac so far.
Fir_Na_Tine
I almost went with the BFG's because I used them before on my old K5 Blazer years ago. They were great back then but I guess things change. Running a set of Falken Wild Peaks AT3 now and so far they are great in the rain and dry roads. Haven't off-roaded them yet though.
HiHoeSilver
Away!
Chicago
The KO2 has greatly improved.
PG01
Up here to the right
Shit, thats all i used to use on all my trucks back in the day.... k5’s and pickups.....they all had KO2’s....never had issues
BFG AT KO... tire that looked great but damn near suicide in the rain.
Neither did our family. I have KO2s and they are plain awesome in the rain. Not just any rain, I'm talking about torrential downpours with the road covered in standing water and visibility down to a few hundred yards, the truck doesn't budge an inch going through that stuff.
HiHoeSilver
Away!
Chicago
There were a lot of hydroplane complaints with the old KO. It is fixed with the KO2.
09 L9H
not a boomer
Upstate SC
Can confirm. KO2s are great rain and dry. I am very satisfied with mine.
M
Mighty Hd
Florida
The ko2 was a HUGE improvement over my KO1. However, no where near as good as these duratrac tires. It should be noted thr duratrac tires do have about 30% more road noise...a very slight hum.
M
Mighty Hd
Florida
Another question.
It appears that I have lost a 1/2” front height over the OEM Z71 shocks with my zone 2” spacer.
Previously I had a very slight Cali-lean and I noticed today the front is now level with the rear. The 5100s are on the “stock height” and I have a zone off-road 2” spacer on the bottom of the strut. Front and rear measures 38-1/4”. The rear has no spacers, only the 5100s. (Maybe the rear was raised a bit? I never measured it)
I REALLY don’t want to disassemble thr shocks again to move the snap ring to the 0.59” setting.
Would i be safe removing the 2” spacer block and installing a 2.5”top coil spacer block from CCM? I can get it swapped over in about an hour...
I have read a lot that a 2.5 may not be safe?
brice715
