Georgia Mountain Rough duty Tahoe. The struggle is real.
OneofFew
OneofFew
Talullah Falls, Ga
I used a big set of c-clamp vise grips and it was easy.
I didn't want to risk warping the pulley or damaging the serp.belt. All my restored vehicles end up being reliable as hell and don't wanna risk damaging myself or something that could bite me later.
OneofFew
OneofFew
Talullah Falls, Ga
Very interested in your progress. There is one good youtube of how to get that brake line in there without dropping the tank.
I'm actually glad I pulled the tank because of the amount of rust I found around the tank mounts and frame, rear cross-member that I was able to remediate. I could have run a new line the non-stock route, but considering the back country gravel roads and mountains around here, I can't have a line vibrating around, chafing and getting hit by rocks.
It won't hurt anything, guys have been doing it that way forever. It just clamps it to the pulley, it can't hurt it. But I changed over to efans anyway, always hated clutch fans.
OneofFew
OneofFew
Talullah Falls, Ga
Another rough day splitting my time working on my house and Tahoe. I quit my job 6 mos ago and I don't see when I would have time for a job:cheers: I promised pics and I did take some, but it seems photobucket hates me and I hate it back. Will see about uploading pics to another host.
Anyway, Flaring steel lines is a pita and next time I will use easybend. But now it is done and the tank put back.In order to reach the fuel lines to disconnect them, I removed the LR wheel and noticed odd wear on the brake rotor, everything looks like shit, so it was hard to tell, but some dumbass had put the inside pad on the outside and vice versa. That made the pad sit crooked on the rotor. I fixed that side, maybe tomorrow I'll fix the other. Also today, I replaced front shocks, hubs, sway bar end links, bled the heck out of the brakes, lubed the joints and the brake components.
Meanwhile the test drive revealed the rear shocks are junk too, at least the RR... add them to the shopping list... the brakes worked well, I had an ABS light till I restarted the engine, parking brakes don't work, radio doesn't play but most importantly: The engine still overheats!!! ARGH :banghead: Running around the area it was fine, even scaling this mountain it did well but it ran about 220 and climbed to 230 idling in my drive.
I am pretty sure the fan clutch that I replaced was bad, it was even squeaking, at least it didnt get as hot as last time... I scratched my head a bit... fresh coolant, new t-stat, new fan and it overheats sitting there idling...the new fan was kicking in intermittently with the A/C blasting. In my head I going back and forth between blaming the water pump and the radiator. More testing to come.
HiHoeSilver
Away!
Chicago
TYF pro tip: click the "upload a file" button, and select your pic (s). The forum will host it for you!
OneofFew
OneofFew
Talullah Falls, Ga
Working on it HiHo. Im not good with things that have no gears. transferring photos from my phone yielded only unsupported media. :confused:
OneofFew
OneofFew
Talullah Falls, Ga
Sitting idling the coolant output flange read 225, input flange 205... This seems like a low spread to me and makes me think I need to replace the radiator. Water pump issues tend to be more evident I think, like a seal or bearing failure. I have seen corroded impellers, but usually there is evidence of rust in the cooling system.
You have 237k miles on it and I'm assuming you're not sure of the water pump? I'd throw a new one before I did anything else, just as a maintenance item anyway. It's relatively inexpensive and easy to replace. That way at least you won't have to worry about it anytime in the future and it could be the problem. Sometimes the impellers just corrode or wear away and they're not that efficient. At least pull it and have a look, especially considering the coolant was funky and may have been replaced with straight water like you mentioned.
OneofFew
OneofFew
Talullah Falls, Ga
I absolutely agree with you on principle, it makes good sense.
OneofFew
OneofFew
Talullah Falls, Ga
Big update: I yanked the radiator, found some gunk in there typical of a system that ran dex-cool past its prime but no big obvious clogs. I found a good deal on a radiator locally and snagged it. Install was of course quick, flushing the rest of the green stuff and refilling took at least the same time. I had 2 gals of what I thought was dexcool on the shelf that turned out to be pure GA mountain water :/ So I had to wait for the next day to fill the system. 2 Gals of Dex and about half a gal of distilled water is all she took. On the way to get gas, she ran great and the temp stayed around 205. Very nice change! I should actually measure the temp drop from flange to flange to get a real idea of radiator performance as it should be.
Yesterday I took it on a stress test. Its about 9 miles round trip dirt road that has big signs '4X4 ONLY- MUST USE 4X4' The reasons being that the road is really steep and marbley going down to a lake. It's definitely 4LO down and up. She never got over 210 degrees with the A/C blasting.
However on the last leg of the trip up my mountain I saw the Oil pressure gauge twitching around lower and lower and as I pulled into my drive and went to idle the low oil pressure light came on. I heard no knocking or lifter noise that would lead me to believe that the oil pressure had indeed bottomed out. I have also pulled that same mountain several times before without oil pressure issues...
I am wondering if 2 things are happening- the cluster is not showing accurately and the oil cooler may be as gunked up as the radiator was and operating at reduced capacity.
I am running fresh Mobil 1 full Syth.
Today I ran it on the highway and it ran about 40 psi at 2k rpm which I feel is great. hot idle tends to be around 25psi. Right now I am brushing this off as a fluke, but will look into replacing the oil cooler since I do put vehicles through hell and this thing has no oil temp gauge.
Damn, fix one problem and another pops up. Typical though when you start doing overdue maintenance.
OneofFew
OneofFew
Talullah Falls, Ga
Exactly, especially this vintage vehicle where most everything is original. I'm trying not to touch too much. because everything I touch I find borderline...
Dexcool I curse you.
Nothing wrong with Dexcool just don't mix it with the green stuff.
So the Dexcool mix is at 50/50 with water now? Dexcool is great, better than green, less corrosive, friendly with aluminum and hoses and has a higher boiling temperature.
As for the oil pressure, change the oil filter and hit the trail again.
OneofFew
OneofFew
Talullah Falls, Ga
I have a spare filter on my shelf I think. The filter only have maybe 40 miles on it now, but the oil that was in the engine before, was way overdue, so it is conceivable that junk got flushed through.
AS to the coolant mix- of course the system was not completely empty when I started filling. I looked into the block drain plug and was like- oh hell no! I read the system holds 15 qts, so 2 gallons of dexcool is about half.
OneofFew
OneofFew
Talullah Falls, Ga
I put another oil filter on this morning and went on the next stress test.
I would have wanted to take it easier on it and changed the trans fluid as it is border-line, but a friend asked me for help to retrieve his camper..... He had wrecked his 09 Tahoe, so he had nothing to pull it with.
The trip was about 90 miles, mostly 2 lanes with just a few moderate pulls. The trip out was uneventful, I was a bit worried about the oil pressure of course and concerned for the health of my trans on the way back, pulling 5k lbs of camper with no external trans oil cooler. The oil pressure stayed pretty constant around 40 psi driving and 25 idling, the coolant temp never went over 210 at all. I was pretty impressed. Th e Tow/Haul button on the shift lever does nothing. No little light comes on in the cluster.
Only on the very last leg to my house on dirt roads did I see the oil pressure lower (around 30 psi) and needle fluttering, especially when accelerating out of a turn. I must assume there is a wiring issue causing that.
When I dropped the camper off, I saw some trans fluid drips. There was no evidence of mayor leaks before- no wet undercarriage, just a few wet spots. When I got home, I got under it and found that there is some sort of vent hose coming from the trans and ends over the transfer case where fluid had dripped from.
The trans was about 1qt overfilled and I assume the extra heat in the trans pushed some excess fluid out.
I will have to investigate further. The trans fluid still looks and smells the same... a bit border-line but still has some pink. I don't think I got it too hot, just hotter that it had been since someone had overfilled the trans.
I am not worried about it right now.
I also determined that my power steering sucks for backing up a trailer... the pump doesn't whine much to where I would suspect a bad power steering pump, fluid is good, but some hoses wet. I will have to see if maybe some clamps on the suction side are letting in air. I have found this the case on other vehicles.
Other things I have to look into are: Why the interior lights don't always come on when opening the driver door, why someone ran an un-fused hot wire into the driver door and why disconnecting it changes nothing, why the aftermarket radio doesn't play. In the near future I will do a trans service and add a trans cooler,
replace the engine oil cooler because I think it is under-performing like my radiator was. Also, the rear track bar is bent a bit, looks like someone slid and hit a curb or something... not an uncommon thing to bend in such a case, but I will leave it be till I get ready to do an alignment.
The daytime running lights are odd.... the headlights come on rather that the DRL lights. It is also acting like it has automatic headlights, turning on the marker lights at dusk, but the headlight switch has no such option. :?
The tow/haul button will have a break in the wire under the srpteering column. Just remove the plastic shroud from around the column and trace the wires from the button to near where theres a connector. The wire will be severed. I just added a short piece and routed it a bit different so the shifter doesn't cut it again. Tow/haul mode will save your trans when pulling a trailer.
OneofFew
OneofFew
Talullah Falls, Ga
Excellent advice! Will do that
OneofFew
OneofFew
Talullah Falls, Ga
Found the break. Mine was broken just under the ignition switch, the break hidden under the 1st clip. What a pain. I ended up taking the knee panel off, finding the connector and disconnecting it, removing the shift lever and fixing the wiring properly on the bench. If it happens again, I will opt to install a toggle switch somewhere else. Tested and the tell tale on the cluster lights up! Happy.
Also today I checked the transfer case level and was surprised to find it in good condition. Nice and blue.
Drewphil
