PPV with Non-PPV Wheels
Hello Everyone,
I have a 2017 PPV. It's my personal vehicle, utilized with FD activity. It is set up as a slick-top vehicle, with no externior markings or lighting. The black PPV wheels are a bit too "police-ish" for my liking, and I'm looking to see what other options look like on the PPV.
If anyone has a PPV with any wheels other than the black steelies, let me see a picture!
aggmeister2010
The Tahoe Pursuits have aluminum wheels. Google: GM Upfitter PPV Wheels.
You mean this kind? I've seen these on what our department calls the "admin package." They look alright, I'm still looking to see what others have done as well!
Rdr854
Northern VA
I’ve seen three wheel types on fire department Suburbans and Tahoes: 17” steel wheels (grey), 18” aluminum wheels that are standard on the LS and 20” aluminum wheels. All of these vehicles are fire department vehicles. Don’t know if they are PPVs or 1FLs.
aggmeister2010
LS wheels from what? It’s not from a current gen LS Tahoe/Suburban
These are the wheels that come with what many Dealerships call the “admin package,” which is a PPV with a factory console and alloy wheels rather than the black ones.
sklmanhoutx
Hello Everyone,
sklmanhoutx
You can any wheel made for a Tahoe, have the wheel company make sure you have the right offset. Your speedometer will be off, but go on Amazon and you can buy a recalibrator $137.00. You can use it only on ONE vehicle, but the thing I didnt know until I recalibrated it was, it use to hang up in passing gear and not shift properly, but once you use the device, which is easy to use, it corrects all the shift points, the speedometer, and all ECM settings affecting the tires, their sizes, gas mileage. It is frickin awesome.
Good luck, Steve
Email: [email protected], if you need additional info.
aggmeister2010
Good luck, Steve
Right, I get that - I'm just trying to see what they actually look like before I pull the trigger on buying any. That's a good tip on the re-calibrator, thank you!
ATX 14
Even though they are black, here are my 20" wheels on my 2016 PPV.
Eod1
If you see me running, I would try to keep up.
Phoenix Arizona
If you do any kinda of offensive or defensive driving you are going to want a pursuit rated wheel. Aluminum wheels don't take the abuse a steel wheel will.
ATX 14
These were the same admin package wheels that came on my 2016 PPV that I bought new. The dealership swapped out those aluminum alloy wheels with my current aftermarket wheels at my request. The pursuit rated Tahoes do come with aluminum wheels but it depends on the police package.
Eod1
Phoenix Arizona
If they have pursuit rated Aluminum wheels that can take the abuse like a steel wheel can, I need the part number please. I would love to get rid of these steel wheels.
Steel Wheels bend...they are easier to replace and handle shock better than alloy wheels. Alloy wheels are stronger but you hit a sharp bump or slam into a curb the wrong way, and you'll crack them. Cracked wheels are much worse and more dangerous than bent ones. Usually you crack or brake a wheel your done
You bend a steel wheel ,you may have to slow down a little but your not out of the race, so to speak.
ATX 14
As you mentioned, both rims have their strengths & weaknesses. Many PPV Tahoes come with aluminum wheels and they are still pursuit rated. The steel rims will be more durable over the long run for sure. I'm guessing most of the people on this forum that own the PPV or SSV aren't driving under pursuit conditions.
DaBigBR
Iowa
I had a thread on this a while back.
I have a '15 PPV that my dealer reprogrammed for the factory 20" wheels. I bought an '18 in January and they were unable up do it for the '18. I bought a speedometer calibrator and it did the trick.
dizhai
