2016 Suburban ltz issues after leveling kit
CCaraway
Good day all,
I appreciate you taking the time to read this. As the title states I have a 2016 Suburban ltz with the magnaride. i just recently installed a ProComp 2.25" leveling kit purchased at an off road parts dealer locally. After I installed the ProComp it was brought to my attention that this kit is not approved for my Suburban because of the Magnaride. The off road store talked to ProComp and it was not approved because ProComp had not completed the testing yet. I got my Suburban back and it drives good however I have a slight clunking coming from the front drivers side. Its not a loud clunk but there is a noise coming from that area. It does not do it all the time, more noticable it when on rough roads or hit bump. After researching this site I do know I need to add the Magnaride brackets and will be purchasing them today but I am not sure if that will fix this noise. Any suggestions are very much appreciated.
Thanks again
Thanks again
01Konvict
Boats n Hoes
Raleigh/SML
Post pics of upper control arms and droop stops. It could be the limiting down travel and need of lift UCAs.
C
CCaraway
Thanks, I have been traveling non stop. I will take pictures as soon as I get back home. Thanks again.
01Konvict
Boats n Hoes
Raleigh/SML
Ok I suspect it’s the upper arm hitting droop stops. You can visually see the arm marks on the stops if there has been contact.
C
CCaraway
Sorry in the delay. Here are some pics of the
I apologize in the delay. Please see pics requested. I installed the magna ride brackets and it rides smoother however the noise is still there. It does not make it all the time just on rough roads bumps etc... Let me know what you think. Thanks again
01Konvict
Boats n Hoes
Raleigh/SML
Thanks for pictures and maybe I wasn’t clear on what to show. Leave the wheel on the truck and under its own weight on the ground. Need the gap between arm and droop stop. I will try to find a similar picture online to show what I’m looking for but I’m pretty positive it’s that area contacting which is the sound you’re hearing
C
CCaraway
Sorry, here they are with tire attached. Not 100% if this is what you are looking for. Thanks again.
MichaelSE
2010 2500
Tucson
So this kit looks like it has a very small lower spacer (looks like .25" for ".5 of level) which means that the remaining 1.75" should come from an upper spacer. Is it possible that they did not properly tighten the bolts that mount the upper spacer to the frame's shock tower OR the bolts that attach the spacer to the shock? Both of those would cause the shock to jiggle around and potentially clunk when you hit a bump. That's where I'd check.
MichaelSE
2010 2500
Tucson
01Konvict
Boats n Hoes
Raleigh/SML
That's much better but doesn't appear to be hitting the droop stops. How does the passenger side look? Get an videos of the sound?
cardude2000
There’s a TSB for clunking in front shocks. I’m getting mine fixed next week.
This and the vibration/buffeting issue could really use a sticky.
C
CCaraway
Thanks for your reply. We checked all the bolts on top and they are tight. It only happens on rough roads or bumps.
C
CCaraway
I’ll get pictures of the passenger side but it looks about the same. I’ll try to get an audio of the noise. Thanks again. Offroad shop is going to take a look at it this morning. Will keep you updated.
DenaliBQ
do you get any rubbing with that tire size ? what is the size 33" ?
Durobans
