PPV 17" wheel center cap bolt size
vetterss
Double Oak, TX.
Does anyone know what the size is for the 3 bolts that retain the chrome center caps on the steel 17" wheels of a 2009 PPV? Searched a bunch of sites but no luck. May have to take one off and try to match it at Lowe's.
AverageBri
They are
M8 - 1.25 x 20mm
I bought a bag of stainless steel versions on amazon (search for "M8 - 1.25 x 20mm A2-70 Stainless Hex Flange Bolts" on their site)
They're really nice and fit perfectly.
Lightning 95
I used the stainless bolts too on mine along with stainless washers. There are suppose to be some small aluminum spacers between the cap and wheel too. I was missing a few and found a 3/8 inch nut slips over the bolt threads to use as a spacer. The cap is not clamped to the wheel around the outside, but by the bolts and spacers.
vetterss
vetterss
Double Oak, TX.
That M8 sizing is right on. I didn't use stainless but just got regular for the meantime to snug up the caps. Will convert over to stainless down the road.
jz57
What is the thickness of the 3/8-inch nut?
AverageBri
I found aluminum spacers at Home Depot that are the same size as the factory spacers. Dimensions are 5/16" inside diameter x 5/8" outside diameter x 7/16" length.
Also, the factory spacers have 2 O-rings that hold the spacer on the bolt from the inside of the center cap. I just used one O-ring, which is 1/4" inside diameter x 3/8" outside diameter.
See attached image for reference.
jz57
Good finding!!
Do you have that Home Depot Aluminum spacer Part #?
GranPrix
Do you have a part number? A receipt with info on it?
marinecorps_vet
Need help!! My center caps won’t stay on because the pilot hole inserts came out. What can I do ??
959C169D-0FEC-4D0F-9969-08902F99FF00.jpeg 0F008706-08A9-4252-851C-26BD565694E4.jpeg
jz57
Re-tapping the hole and use a over-size bolt with the length of 20MM
CrashTestDummy
Pearland, Texas
View attachment 214041 View attachment 214042
Get replacement captive nuts and peen them in after installing:
https://www.mcmaster.com/captive-nuts
Or, if the ribbing is gone in the wheel, maybe use rivit nuts?
https://www.mcmaster.com/standard-rivet-nuts
I'd use an anti-sieze on the threaded part after installing, though, so the bolts will come out when you want them to.
Drewphil
